Question about La Crosse Technology La Crosse S98642 Wireless Atomic Color Weather
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with the s 98642 Weather Station! Makes me begin to wonder what is going on I have also discovered several other weather stations are discontinued on many of the online stores? I need a new sensor or another weather station! This weather station has given me trouble ever since we bought it in one way or another! Jim Carpenter [email protected] yahoo.com
Posted by Jim Carpenter on
Tom Chichester
    Top Expert:
  • La Crosse Te... Master
  • 56,023 Answers
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Posted on Nov 04, 2013
My LCD start shaking and flashing 3 days ago and this case continues like this . I did reset from the setting manue but no use I should set the Brightness at 100% and this is not good for my eyes...
Press the Menu switch in you LCD monitor and hold it continuosly for 6 seconds, a message will be displayed.
OR
Press Menu switch then go to SETUP option and Set FACTORY RESET to YES, it will reset all your monitor settings.
May 18, 2011 | Videoseven L19CM 19" LCD Monitor
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as...
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Feb 02, 2011 | LG LSC121PMA Split System Air Conditioner
The TV can't be operated by the remote anymore. I changed the batteries with new ones, unplugged the tv for a night and did a factory reset but nothing helped. It's not the remote because my universal...
The remote IR receiver may have gone out, or the logic board is not processing the IR signal from the IR receiver board. You can check and see if the IR receiver board is getting 5vdc feeding it.
See the parts for your TV here: www.shopjimmy.com
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 25, 2010 | Vizio L32 32 in. LCD HDTV
Remote sensor does not work. Have tried three different remotes
Your problem can be from any of these: Main Board, IR Sensor or Remote. Watch the youtube video attached to diagnose it correctly.
Feb 02, 2010 | Hyundai ImageQuest HQL320WR 32 in....
Red color is completely gone out of the LCD flat screen
You can try performing a factory reset of the TV. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. Good luck!
Jan 12, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a Polaroid 1913 TDXB with the original remote just a few days ago it stopped working it has fresh batteries. I assume the remote has reset it's self is there a code for it?
Take the remote aparts,clean it with a Q tip with some rubbing alcahol.Clean the rubbers films and the circuits board.Clean IR in the tv and the remote.After this still don't work ur remote it dead,by the main CPU,it junk know.Here a website to buy a new one 1-800-Remotes Factory original.Never have need codes for oiginal remotes.
Nov 03, 2009 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Autoprograming
get the original remote.....i had to. it costs $95 thru best buy(special order it takes 5 days)
Sep 15, 2007 | Mitsubishi VS-60603 60" Rear Projection...
La Crosse Technology La Crosse S98642 Wireless Atomic Color Weather Logo
1,265 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
robert
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
