Question about Motorola Mag One BPR40 Two Way Radio
Program software compatible - Motorola Mag One BPR40 Two Way Radio
The software for my Feiyue EM3000 embroidery machine does not work on my Windows 7 laptop, where can I get software to run my machine?
One may go through the windows XP for sure.
Use program compatibility wizard and you'll be able to use the same program in Windows XP also.
  • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
http://mhelpdesk.com/field-service-management-software/
Oct 12, 2013 | Sewing Machines
My mom will only use CreataCard Gold 3 but uses Windows 7. How can she still keep using it?
Does the software install properly in Windows 7? If you are having installation problem then you can try running the installer (most of the time it is "setup.exe") in "compatibility mode".
To run a program in comparability mode right click on the executable (i.e "setup.exe") and select "properties" then click on the "Compatibility" tab. In the "Compatibility" tab select the check mark next to "Run this program in compatibility mode for:" option then from the pull down menu select "Windows XP (Service Pack 2 or 3)".
After installing the program if you run into issues while using the program then use the same steps to run the program in Windows XP compatibility mode.
Sep 06, 2011 | Broderbund American Greetings Creatacard...
How to solve error message C00D11B1
Computer program errors are discussable. First, the programs require compatibility to the entire computer system to take effects either as downloads or installation from internet of disk drives. Computer software programs have compatibility versions to each system innovated. For example, windows media player version 9 or earlier is installable on older computers where version 10 above compatible to recent innovated computers. In situations that computer least captures the window media player effect requires acquiring another media player. For example, real one media player has the compatibilities to generic device either Microsoft of apple Mac computers. Also, available are generic media programs that least requires compatibilities to install however least has satisfactory expectations discussable. Error observations are solvable either as attaining an alternate program software least incompatible or capturing a computer that is compatible to the program requesting installation.
Feb 28, 2011 | Microsoft Windows Media Player
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
Future CE-250 software compatible with Windows 7?
I just bought a new Futura CE250 & had the same problem.
I fixed my "can not run an x86 build of this utility on x64 platform" by visiting the futura support website & downloading a service update. I have a computer with Windows 7 installed.
The website is www.futura-support.com
When you are there, click on the link on the left for "Service Updates."
The actual link to where I downloaded my udate is: http://www.futura-support.com/downloads/ce150.html
Happy Embroidering!!!
Jan 19, 2010 | Singer CE-200 Quantum Futura Computerized...
Husqvarna 1 Embroidery software
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Dec 20, 2008 | Husqvarna Viking 1
I am trying to install my software on my new computer, ia the Windows Vista
Read the system requirements of the software...if it is software made for another operating system ..... Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
• Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
NoteTo find out if your programs (or programs you plan to buy) are compatible with Windows Vista, go online to the Windows Vista Compatibility Center. This website contains a comprehensive list of programs, computers, and devices that have been tested to work with Windows Vista.
Oct 23, 2008 | Computers & Internet
Jvc camcorder GZ-MG20U 20 GB hdd
the makers of the bundled software offer a lower price for updates from the bundle version
http://www.cyberlink.com/multi/cyberstore/dr/product_upgrade.jsp
version 7 is vista compatible
You may be able to run the program in Vista 'compatibility mode'
  • Right click the executable and click the Properties option.
  • Select the Compatibility tab.
  • Select the Run This Program in Compatibility Mode option.
  • From the drop-down list, choose the operating system you ran before upgrading to Vista.
  • If necessary, select the option to run the program as an administration.
  • Click OK.
Jul 15, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Coolpix software
Hi
you have to download Nikon transfer program, check compatibility on this site, click HERE
then click on the link where you can download the program
pls rate as fixya if it helps thanks
Jul 05, 2008 | Nikon COOLPIX S200 Digital Camera
Ulead dvd workshop 2
You can install and run a Ulead software for Windows XP on Windows Vista by running
the Program Compatibility Wizard. We do not guarantee full stability for Windows Vista though.
To run Program Compatibility Wizard:
1. Open the "Program Compatibility Wizard" by
clicking the [Start] button, clicking [Control Panel], clicking [Programs],
and then clicking "Use an older program with this version of Windows".
2. Click [Next] when the "Program Compatibility Wizard" dialog box comes up.
3. Select "I want to use the program in the CD-ROM drive" and click [Next].
If the installer is not detected from the CD-ROM drive, please manually browse for the installer executable.
4. Under "Select a compatibility mode for the program" step, please click on "Microsoft Windows XP (SP2)" and click [Next].
5. For the display settings, please click on "Disable Visual Themes" and "Disable desktop composition" then click [Next].
6. Click on "Run this program as an administrator" and click [Next].
7. Click [Next] to start testing the compatibility settings.
This will launch the installer so if you have your firewall enabled, it will prompt for a permission request.
Please grant permission for the setup to continue. 8. The setup will now run.
You can allow it to finish or switch back to the "Program Compatibility Wizard" dialog box.
9. It will ask you if the program ran correctly. Click "Yes..." if no other pop-ups appear.
* Try another compatibility setting if it reports a problem with the display. For the display settings,
enable the option "Disable display scaling on high DPI settings" as well.
10. For this next step click "Yes" to send the info to Microsoft and finish the process.
* Now that you have the software installed, you will also have to run the "Program Compatibility Wizard"
for the application to run correctly. Use the same procedure except for step [3],
select "I want to choose from a list of programs". Follow the same procedure for the other steps until you finish the setup.
Nov 16, 2007 | Ulead DVD Workshop 2 for PC
Motorola Mag One BPR40 Two Way Radio Logo
37 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
