Question about PfaFF Sewing Machines
Pedal foot is not working - PfaFF Sewing Machines
Posted by Susan on
MissFixIt828
    New Friend:
  • 70 Answers
You should take it to a repair tech and see if they will give you a free estimate. If your foot control needs to be replaced it can cost anywhere from $50-$300 for a replacement. You may just need a new cord ($20?) or the motor could be dead.
Posted on Nov 06, 2013
Viking rose 609 model foot pedal will not work
I would suggest you replace the foot pedal speed control.
Jan 10, 2017 | Sewing Machines
My foot pedal doesn't work.
Have you tried using a new foot pedal? I think it would be worth the the money because moving parts tend to go bad before internal stationary ones. Amazon com Singer Sewing Machine Foot Pedal Everything Else
Apr 22, 2016 | Sewing Machines
Foot pedal isn't working
if the foot pedal is plugged in correctly, you may need to replace the foot pedal or have the plug that the foot pedal plugs into checked
Feb 29, 2016 | PfaFF Sewing Machines
My Brother Project Runway sewing machine's foot pedal is not working. No power. Is there a solution?
you can take the sewing machine and foot pedal to a repair shop and have them check the foot pedal and they can tell you if you need a new foot pedal or if that one can be fixed.
Aug 09, 2013 | Brother Ls2250prw Project Runway...
Toyota sewing machine foot pedal unresponsive then goes really fast.
Try to get another foot pedal. If that works then replace.
Oct 08, 2012 | Toyota Sewing Machines
Foot pedal not working
yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Aug 27, 2012 | PfaFF Tiptronic 2040
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
You may need a new foot pedal. Find a small applicance repair shop and ask them if they can test the pedal. Take the machine with you.
Mar 09, 2010 | Husqvarna Designer I
My unit has no power to foot pedal. What are possible fixes?
change the power chord of your pedal, if not, open the pedal and look for the connection if that is cut or loose try to tight or connect it.
Oct 17, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
62 people viewed this question
Top PfaFF Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Asmodius
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
