Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Need to determine the kind of power supply it requires. I have lost the original and need to replace it.
Posted by Deanna Turner on
pramey3
    New Friend:
  • 22 Answers
Need replacement power supply
JBL parts online
ebay seller has this listing
AC Adapter For JBL on stage 400p Speaker Dock iPhone iPod OS400PBLK Power...
the power source specs are on a sticker on the device or online search for its specs
nothing wrong with universal power supplier from an after market power source supplier
Mar 22, 2017 | JBL Audio Players & Recorders
Required output voltages from an acoustic solution lcd television power supply unit
Only the original supply is going to work---schematics with voltages and wave forms are rarely available online except to a authorized service center for that brand---they want to SELL REPLACEMENT boards and not have someone fix them.
Jun 15, 2012 | Televison & Video
I have a Maxtor external driver and the AC adapter is not working. I need a new AC adapter and local stores do not have it. How can you help?
There are "generic" power supplies that might meet your needs.
This is a response I gave to another user who had a different external HDD and needed a power supply.
The hard drive unit itself should be able to supply you with the required DC input voltage (hopefully there is some kind of label on the enclosure).
You could try one of these or something similar. It comes with 6 interchangeable heads and has adjustable DC voltage. This is just one of many available.
http://www.amazon.com/Hosa-ACD477-100-240V-Voltage-Adaptor/dp/B000Z31G3M
I cannot guarantee any of these supplied heads will fit your particular drive (same with the dc voltage). Some local retailers
often have these types of adapters and you might be able to determine what size you need by looking at one. Most of the
Externall HDD need 12VDC and 18+ watts of power.
Here is an online site also.
www.12Vadapters.com
I have used DC units similar to these in the past when I have lost a power supply.
Hopefully with a minimum of effort you can get a working solution.
Feb 24, 2011 | Maxtor Computers & Internet
Lost or misplaced power supply for Beyond Micro Micro Model BMMDU2 External hard Drive. Need info on Wattage input. Please and Thanks if you're able to hrlp.
Well, looks like Beyond Mico web site has gone to the great Beyond.
From units I have been able to find online, it looks like the power supply is between 20 and 40 watts.
I cannot guarentee any of these supplied heads will fit your particular drive (same with the dc voltage). But some local retailers often have these types of adapters and you might be able to determine what size you need by looking at one.
Dec 28, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
What voltage and amperage the western digital wd25001032-001 will work. I lost the original power supply and need replacement.
Mine has a 12V 4A power supply. This is not generally available as a generic replacement, due to the high current required. Good luck!
Feb 21, 2010 | Western Digital 250GB MyBook External USB...
STRANGE PICTURE ,TVS PICTURE PULLED IN FROM TOP AND BOTTOM AND BOTH SIDES ,,PICTURE LOOKS LIKE BUTTERFLY IN CENTER OF SCREEN ,,
I would say you have a power supply or deflection system defect. This would need a technician to diagnose the problem as it will require some tests to determine where the problem is originating. For example, a main power supply defect could cause reduced supply voltage which would affect both vertical and horizontal deflection.
Nov 25, 2009 | Samsung TXM3096WHF 30" TV
I have a Q-Stor 7 port USB hub, Model QU2RCT7. I
I don't have the original power supply for my QU2RCT7 either, but most hubs use a 5v DC power adapter, typically with a 2A. (2 amp) rating. I'm using such an adapter with my QU2RCT7 and it works fine. Make sure the adapter you select is tip-positive (ie, the "+" terminal is the "tip," or center, of the connector).
Sep 14, 2009 | QPS (QU2RCT7) 7-Port USB Hub
I lost the power supply for SPDPF84M picture frame, can you give me voltage requirements. Thanks in advance
12 V
0.6 A
positive on center pin, negative = outer shell.
original model # is HNC120060U
If you're getting something other than the original power supply, I would suggest going with maybe a 1 A power supply, the std one gets kinda hot, and heat isn't very good for many electrical / electronic components
Aug 12, 2009 | SmartParts (1DPFSP01) Digital Picture...
Lost power supply need one. what are amps and volts requirements
just get one like the one that went out. id recommend a 600 watt power supply xion.com has good one
make a list or notes if you must or replace one lead at time and make a note of where it goes before you disconnect it '
the reason im recommending a 600 watt is most power supplies are marginal to begin with in my opinion. so getting a higher rated unit allows you to add accessories you might want to adds
i burned up a chief max 600 watt in a month for some reason replaced it with a 425 till i got a new one and bought a 600 watt xion.com power supply the original was 425 watt. i guess i got what i paid for the chief max was only 28 dolara from 3btech.net (a good site to bookmark
May 16, 2009 | Western Digital External USB 2.0 80 GB...
Microsoft Force Feedback 2 joystick - Lost Power Supply.
Hope this helps.
Part No. 96749 (Maybe Ebay?)
Input: 230V~ 50Hz
0.15A
Output: 12V 1.3A
Apr 28, 2008 | Microsoft SideWinder Force Feedback 2...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
82 people viewed this question
Top SimpleTech Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Jax Planet
Jax Planet
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
