Question about Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor
My k9 car alarm system has a kill switch and somehow was activated while I was driving today. It makes a knocking sound except for when I have the key in the ignition turned on or if i push a button in my car and I can't get my car to turn on anymore. How do I deactivate the kill switch or how do I take it out?
Posted by Larry Miller on
Craig Lovick
    Sergeant:
  • 247 Answers
Usually if you unplug the after market alarm system it will let you start and drive your vehicle.
Posted on Nov 04, 2013
Hassel Lee
    New Friend:
  • 157 Answers
I guess doing at your own is pretty dangerous for your car lock/alarm system. Rather that doing at your own you should call locksmith guy to fix it. You can see the website locksmith in san francisco and follow the manual guide of car lock system. Or you can call company's owner to fix this issue.
Posted on Nov 08, 2013
Key alarm sounds even after key is removed. Drained battery.
Make sure your Battery is fully charged. A partially charged Battery can make the alarm system malfunction. Also, make sure the
regulator is charging the Battery. Some key alarm systems can
and will drain your battery if the Car is rarely driven especially
if there is a ignition kill switch wired into the system. The key alarm
system on my Mercedes 560SL used to drain my battery whenever
I didn't drive the car enough.
Sep 08, 2017 | Cars & Trucks
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
How to turn kill switch off and see manual and instructions
I am assuming that you want to disable the system temporarily by putting it in valet mode. You will need to locate the valet button; they are usually installed under the dash within reach of the driver. The button should be black and about 1/2" in diameter.
Pressing and holding the button for 3 seconds while the alarm is disarmed will put the system into valet mode. The system will turn the LED light on steady and chirp the siren to indicate that valet mode has been activated. To exit valet mode, press and release the button. The LED will turn off and the siren will chirp to indicate that you have exited valet mode.
The included link is for the manual, see page 8.
http://www.caralarm.com/manuals/K-9/K9-Mundial-ss.pdf
Nov 03, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
I have a 1997 honda accord with an aftermarket audiovox car alarm installed. I want to disable the alarm or at least disable the kill switch. The key fob is going bad, I do not have a manual. It is not...
Look for some sort of toggle switch associated with the alarm system. (something small similar to this [http://www.mouser.com/images/ckcomponents/lrg/7000_toggle_series_new_SPL.jpg]) They call this a valet switch and it's located somewhere hidden and out of the way - usually under the dash - but still in an accessible spot. This basically disables the alarm. Typically, you'd turn the key on (but engine off) then flip the switch. This will put the car into valet mode and basically disable it. There is also usually some sort of LED light associated with the system - again typically blinking when the system is armed - but it will be solid once in valet mode. The clicking you are hearing is the relay that is triggering things. I'm assuming someone got tired of the alarm sounding and got rid of the siren it or clipped the wires to it - hence why your only hearing the clicking and seeing the light flash.
Mar 21, 2017 | Car APS95BT2 2-Button Code Learning...
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
Remote start won't start the car...
put key in ignition switch leave in the off position, press the remote starter, if your car starts it is the transponder system it may need to be adjusted
Jan 12, 2010 | DEI Python 1400XP Remote Start/Keyless...
2000 hyundai elantra alarm goes off where is the
There is NO kill switch on the 2000 Elantra... HOWEVER, there is a thing called the Key Fob (keyless remote entry system). There is, however, a system in place called the 'starter kill' circuit and it is activated when the burglar alarm goes off.... it's called the burglar alarm relay and it is activated to prevent the engine starter system from being used. There are three ways to get the engine started in such a circumstance... 1. use the key fob to 'disarm' the system... 2. put the key in the ignition and turn it to the 'RUN" position and wait until the alarm stops (horn stops beeping and the parking lights stop flashing), then the engine will start.... 3. pull the starter relay from the UnderHood junction box and bypass the starter circuit (key in ignition and in the 'RUN' position), jumper the starter solenoid circuit to energize the solenoid to start cranking the engine -- it should start then.
Oct 03, 2009 | 2000 Hyundai Elantra
Car horn and lights sound alarm @ random times while parked
Alarm Disarm LIGHT GREEN (-) DRIVER'S KICK PANEL
Jun 10, 2009 | Aiwa CDC-X504MP CD Player
Kill switch automatically activates
try pulling the relay or fuse out for alarm system.if it starts then replace fuse or relay.if it still doesn't start then your alarm system has a control module that needs replacing.
Mar 27, 2009 | 2002 Toyota Camry
When I turn the key off, it is like disconnecting the battery.
Does the car have a battery kill switch installed with its alarm system? It sounds as though when you cut off the key it engages the kill switch which removes power from the vehicle when the key is removed and the alarm is tripped.
Jan 01, 2009 | 1998 Dodge Caravan
Excalibur. K9-MUNDIAL-SS Entry Level Auto Alarm with Dual Zone Shock Sensor Logo
614 people viewed this question
Top Dual Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Dual Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
