Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
Posted by Nan Schaibly on
  • Nan Schaibly
    Nan Schaibly Nov 04, 2013
    I've looked everyone on the schematics for the cleaner and I can't see where there is a belt that I could change. I'm baffled!
Corky's Craft Shop
    Novelist:
  • 210 Answers
Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
Posted on Nov 04, 2013
  • Nan Schaibly
5 Related Answers
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: Hoover Windtunnel
Sounds like you have a bad brush roll(48414115), take it out and see the the ends turn freely or not, if not, then replace it. Also check the the slots that the brush roll sits in to make sure they haven't melted. I am assuming that the motor is running, if not, then it may have froze up.
Posted on Feb 28, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: rubber smell, Hoover
Its your belt burning up. You have to take the bottom of the unit off to check the belt to see if it was rubbing against something or if it is broken.
Posted on Jun 30, 2008
Anonymous
SOURCE: Vacuum smells like burning rubber
Usually when my vacuum smells like burning rubber, the belt needs to be changed and that is very easy to do. You just need to remove the the screws that hold in the rotator and put in a new belt. When the belt needs to be changed the vacuum will not pick up anything and this could make it seem like there is no suction. I hope this helps!
Posted on Nov 25, 2008
Anonymous
  • 3 Answers
SOURCE: My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Posted on Mar 15, 2009
rkintz
  • 190 Answers
SOURCE: Hoover steam vac doesn't pick up all cleaning
Please look to make sure the rubber ring gasket is still in place under the recovery tank. The tube on the bottom of the recovery tank must seal to the rubber ring to get suction.
Posted on Dec 31, 2009
Powerhead won't rotate on low-pile carpet
Sounds like the vacuum is adjusted too low on the carpet. Adjust it to a higher level. If this is not the problem, then the belt is slipping. Buy a new belt.
Dec 02, 2015 | Hoover Vacuums
Hoover advance path steamer practically new started smelling like burning now won't turn on
Service Center Locator - Hoover
hoover.com/locator/
The Hoover CompanyFloormate Scrub Cleaners · Steam Cleaners · Stick Vacuums · Carpet Cleaners · Parts & Solutions · Search Parts · Bags · Belts · Filters · Cleaning Solutions.Missing: advancepath
Hoover steamvac repair - YouTube
? 6:16
https://www.youtube.com/watch?v=cyenpuw2XyM
Apr 23, 2014 - Uploaded by BCtruck, rebuild, repair,repurpose
Its ben two years since we had the carpet in the sunroom steamcleaned. It pains me to pay someone else to ...
Nov 07, 2015 | Hoover Vacuums
Wont move forward or backwards
Generally the belt is probably stretched and needs replacing but I have had several that required modifying the height adjustment assembly. Belt should be a bit of a fight to stretch and get the brush block back in properly to maintain resistance. The higher carpet causes the belt to slip and can even cause burn/wear from the motor shaft spinning in one spot. Sometimes people run them and burn through and break the belt. Generally you smell rubber burning if belt is slipping and burning. The height adjustment modification was a last resort and not easy! Not for the average person! Another post tells how to modify but better be handy!
Dec 07, 2013 | Hoover Vacuums
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
When I try to use the carpet cleaner thaer is a
most likely the smell you get is the motor putting off a smell like a really bad, but not electrical smell. hope this helps. suggestions : try to take it to your local vac shop to see what the problem is.
Jul 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hover steam vac Model #F5897-900
When I use my Hover Steam Vac, it smells like rubber is burning. How do I fix this?
Jun 16, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuum smells like burning rubber when on, no suction, leaving black marks on carpet
Nov 25, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover F6025900 Steam Vac Widepath LS, I own this steam vac and I found bits of rubber under the machine when I turned it on, smelled like burned rubber from a belt? Can you please tell me if there is a...
Well there is no belt, and not sure what the rubber would be from, everything is plastic or metal. Unless it is really an electrical smell, which means the motor is going bad.
Jun 22, 2008 | Hoover Vacuums
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
1,183 people viewed this question
Top Hoover Vacuums Experts
Marvin
Marvin
Mike
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
