Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
The power went out in town, the power came back on, and the power is on to the hot tub, but we got an F2 code, and it isn't going on to cycle and the temp is at 54 now. What is the F2 code. We have a great lakes traverse bay hot tub.
Posted by Victoria Kearney... on
Nicky Bell
    Scholar:
  • 94 Answers
I need to know what kind of control pack your tub has. If you can open the side panel and tell me what brand the pack is I can tell you what the error code is for.
Posted on Nov 05, 2013
4 Related Answers
Anonymous
  • 247 Answers
SOURCE: no power to hot tub...
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
Posted on May 25, 2009
Anonymous
  • 37 Answers
SOURCE: i cannt trun on my great lake hot tub it is
either filter issue or temp sensor
Posted on Oct 11, 2009
Dale Cobb
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
Ian  Hot Tub
Ian Kime
  • 77 Answers
SOURCE: Error code reads
'Sn' is a general error message relating to the temperature sensors.
Assuming that you have a Balboa spa pack (M7 version), turn off the power and remove the spa pack cover, you'll find two temperature sensors mounted in the top of the heater tube one at each end. Follow the wiring from the sensor to the plug(s) on the PCB and check that the connections are good, they have a habit of devekoping a poor connection.
If you have a multimeter you could also check the resistance of the two sensors. They should both be the same. If they aren't the same you'll probably have to replace them.
One final thing just to check... Ensure that there are no blockages within the heater. Unless you have service/gate valves you will have to drain the hot tub, unscrew the unions and check inside the heater for debris within the heater assembly.
If you're from the UK I may be able to help regarding parts etc.
Kind Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 08, 2010
Loud noises during spin cycle. Drum is eating up. All springs and shocks appear to be ok
The water seal has worn out and water has gotten into the bearings. You need to call a service tech to have it repaired. It is not a cheap repair. Whirlpool has a repair that replaces the back half of outer tub and a new inner tub or basket one in the same. Another salution is replace the seal and bearings, still a lot of labor. go to utube and a guy does to an LG, but the the repair is about the same for a Duet
Aug 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code 2004
Balboa Direct has an excellent error code listing on their site.
Mar 29, 2014 | Pool & Spa
How do you reset an imperial hot tub flo control panel? this one is 10 yrs old.
shut it off entirely .. unplug..reconnect and power it back up reset all settings..
Nov 21, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
We have a brand new Oasis Mohave spa and we wanted to run through a full cycle so we ran the tub for a week, no problems. then we drained and refilled the tub. Now we get dr or dy as error codes on the...
The dr error code is for "dry". Meaning that the control system is not sensing that water is flowing through the heating element.
With a new spa, and you just having drained it , it is probably an air locked pump.
What this means is that you have a small constant circulation pump with not much power, that got ait trapped in it when you drained. When you went to start back up, this "air lock" prevented the pump from fully priming.
Power down the spa at the breaker. Remove the filter element.Stick a garden hose with lots of pressure into the skimmer hole and open the hose valve to let water inject into the skimmer.
Restore power to the spa and check operation.
If after attempting this a few times you still get the code, there is an issue with your flowswitch, or with your circulation pump.
With a brand new spa, id like to hope that you just have an air lock.
Good luck
Mar 16, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
We just received an F2 error on the washer? how
Well it depends is it an F2 or an F02.. Two different codes.. an F2 code or and (F ) code could be electrical variables "F" Variables [F4 to F16] (Electrical Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START.
"FO2" (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Hope that helps I just went to www.sears.com/parts typed your model you were missing a diget on the end picked one located the owners manual on manage my home and went to trouble shooting all else fails it says calls for service.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting a E2 F2 code on my kenmore electric range model 95014102, pressing the clear button does nothing, I unplugged the stove and the code went out for a few days it is back on. What could be the...
The E2 F2 is an indication that the oven got too hot and shut down. If the oven actually got too hot the issue is most likely the main control board. If the oven did not get too hot the problem would be the sensor.
May 08, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Spa went over set temperature with loc message
How far over the set temperature did the hot tub go?
A hot tub may sometimes exceed the set temperature slightly especially if it's well insulated and has been on a long filtration cycle.
'Loc' usually means that the keyad is locked or partially locked. Check your quick reference guide and it will tell you how to remove the keypad lock.
Regards,
Ian.
Apr 05, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 16, 2010 | GE Ovens
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
F2 code
go back to drain pump.. pull pump out ckd the impeller on motor pump shaft there should be a slight resistance when the impeller is turned by hand ..have seen impeller come loose of motor shaft and free wheel
Aug 27, 2008 | Kenmore Elite 45986 Front Load Washer
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
333 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Tom Chichester
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
