Question about Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1
Fujitsu ASU12RLS2 indoor fan stopped working error code "Indoor unit fan motor error". The fan spins freely but won't run. About 30 sec after turning on and cover opens, lights blink error code. Unit worked perfectly for 6 months, but after a month of not being used, first time I tried to use it got error described.
Posted by Moody Barrick on
  • Moody Barrick
    Moody Barrick Nov 17, 2013
    Would the room sensor prevent the fan from running if the "Mode" is set to "Fan" on the remote?
R Subramaniyam Iyer
  • 2,133 Answers
Problem with room sensor. Room sensor fixed in the evaparator coil. Plz replace the sensor alone.
Posted on Nov 16, 2013
5 Related Answers
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
Anonymous
  • 21 Answers
SOURCE: model#asu9cq error code
need model and make, and serial if you have it, its an error code, but without make, cant tell u!
Posted on Aug 06, 2009
Anonymous
  • 10 Answers
SOURCE: fujitsu outdoor unit not working
Its possible there has been a power spike and it has dammaged the power pcb. Remove the cover and inpect the PCB's for blackening. If any blakening replace the damaged PCB.
Posted on Jul 15, 2010
Anonymous
  • 10 Answers
SOURCE: How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
lafer
  • 3 Answers
SOURCE: fan noise indoor unit (asu12rlq) fujitsu
A high pitched noise from the fan unit, means a bearing issue from the motor. You must replace the fan motor to get rid of the noise.
Posted on Jan 08, 2012
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Initially fan in indoor unit was surging,cutting in and out,now has stopped completely and red/green flash twice followed by red flashing 4 times
The flashing indicates a fault code. Not knowing what make / model you have makes it impossible to determine the exact fault. If the indoor fan was running erratically, it may just be a fan capacitor on the indoor unit. Some units have a separate capacitor, some have the capacitor mounted on the main indoor control board. Check and see if the fan starts if you give it a flick to start it spinning when you turn the air con on. If it runs and the error flash does not appear, then you will know its a fan capacitor.
Apr 12, 2015 | Heating & Cooling
F6 error code on Frigidaire split unit ac, model FSC12CM6J/FSE12CM6J. Solution says to check fuse? Where is this located?
It seems like the indoor fan is not running. Quite a few split systems have a fuse on the indoor board. It will require stripping off the outer cover of the indoor unit and removal of the electronic box cover. The indoor board is in there. The fuse may be replaceable or it may be a type that is soldered on which makes it virtually non replaceable. ( A new indoor board will be required) Make sure all power is turned off or disconnected before you do anything. Another possibility is the fan motor start capacitor has failed. Try this first before stripping the unit. When the unit is turned on and the outdoor unit has started, give the indoor fan barrel a flick with your finger to start it spinning, if it keeps spinning and the error doesn't appear, it would indicate that the fan motor start capacitor has failed. The capacitors on indoor units are normally small black square boxes with 2 terminals on it. These capacitors are mounted inside or close to where the indoor electronic box is. Again, make sure all power is disconnected or turned off at the meter box before you do any disassembly.
Apr 09, 2014 | Frigidaire Heating & Cooling
Fan noise indoor unit (asu12rlq) fujitsu
Dec 17, 2011 | Fujitsu 24R1 Air Conditioner
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
I have a Fujitsu inverter split system,(ASTA18LCC) which the power was removed for a while. Now when you start it up on any mode the red operation light is on briefely, then the green timer light flashers...
To work out what the error code ispress the orange start/stop button on the remote controller so unit operationis stopped.
Then press and hold "energy save" and "zone control" buttonsimultaneously for at least five seconds, the error code will be along thelines of En:nn where the "En:" is the error code and the":nn" indicates the indoor unit address if there are multiple indoorunits connected to the one controller. If the upper vertical bar on the capitalE is missing so it looks maybe like a 2 or something don't worry for somereasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check ifthere is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsatingbetween terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC itwill cause this error, the problem is normally dry capacitors in the 12 VDCpower supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
Is it helpful?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
My fan stop working the blades are not turning and all it does it's a noise but it don't spin
Is this your indoor fan (this isn't a window unit is it)? Turn the power off and make sure the fan spins freely by hand. If it does then check the capacitor for the fan. If it doesn't spin freely then you may need a new fan motor.
Aug 23, 2010 | Heating & Cooling
Fujitsu split level
Check for errors like blinking indoor light if present. Reset the error by disconnecting power supply from the unit for 10 sec. and "on" the unit. If the error persist, some parts of the unit may be defective and need to replace. Like room air thermistor, coil thermistor in the indoor side or the relay board. Some safety device in the outdoor may give in, some outdoor parts may be defective. You need a qualified technician for the this problem.
May 17, 2008 | Fujitsu 24C1 Air Conditioner
Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1 Logo
645 people viewed this question
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Fahr Quad
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
