Question about Homelite For Excell - Pressure Washer Pump 2700 Psi 7/8" Shaft
Excell Pressure Washer EXHA2425-1 has no pressure. Replaced pump with a new oiled pump from APW Distributing (PW24/2.3L Replacement Pump). After installing the new pup and using the existing wand still no pressure. Replaced the wand with a Blue Hawk 4000 PSI Pressure washer gun kit, still no pressure. Only thing I haven't replaced is the hose with is not suspect at this point. Any ideas would be much appreciated.
Posted by Michael Tinaza on
Behind_Blue_Eyes
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Thermal relief valve would be a start. but is the pump actually turning... are you on city water or well water...
Posted on Nov 15, 2013
My Excell Pressure Washer XR 2750 won't start. I believe it's a timing problem. How can I solve this problem?
You'll need to know who manufactured the motor (Honda, Briggs & Stratton, etc) along with the model and serial number. With that information, you can do an online search for small engine repair manuals and retrieve the specs for you particular motor.
You can even call your local outdoor power equipment repair shop, they'll provide you answers to your questions.
Nov 27, 2013 | Homelite For Excell - Pressure Washer Pump...
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
I have a ic2 pump on my pressure washer, the diagrams have failed. My question is I need the parts to repair it, or how to purchase a replacement.
You can purchase a complete unit from Grainger for about $210.00. Their part number is 6UZP8. And in most cases they are located locally, so you can pick it up and be back in business quick. The pump is actually manufactured by Excell Power, so my thought would be replace the pump and then try to find a rebuild kit for the bad pump and try to rebuild it as a backup. Hope this helps.
http://www.grainger.com/Grainger/EXCELL-Assembly-Pump-6UZP8
Jun 13, 2011 | Honda Garden
I have a Pressure Washer VR2500 , 6.5 horsepower / 2500 PSI number on side 123K12-0134-E Residential - Excell. I do not know which is the oil drain plug for the Pump on the bottom. There is an Allens...
Hi and welcome to FixYa, I am Kelly
First here is the owders manual:
http://www.excellpressurewasher.com/documents/pdf/D30494-E.pdf
There are 3 versions of the VR2500 Pressure Washer.
1 being the VR2500 Type 0 It has the comet pump that needs no oil
2 being the VR2500 Type 1 Also with the comet pump.
3 being the VR2500-C Again with the coment pump
The allen set screws that you removed hold the bearings in place.
The only pump maintence required is winterization with either a winterizer EX80 or RV anti-freeze
PUMP
The manufacturer recommends using
a pump protector/winterizer, such as
EX80, when storing the unit for more
than 30 days and/or when freezing
temperatures are expected. If a pump
protector/winterizer is not available,
*RV antifreeze needs to be run through
the pump as outlined in the steps
below.
EXCell does make units that have an AR pump that requires pump oil. The VR2500 pump does not.
Thanks for choosing FixYa.
Kelly
Dec 06, 2010 | Comet GXD2527G Pressure Washer Pump
My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
Good news, your engine runs
But your pump may be bad
Here's how to test your pump
Check oil as outlined lower down
Disconnect the washer hose and gun
Connect water hose and turn on water and water should pass straight through the pump
Look for clogs in the hose-end where water hose connects to machine
Turn on machine and see if water shoots out pump
If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
Look for clogs in the end of each water connection.
Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
Finally, the gun trigger mechanism may be bad
I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
Check your pump oil
Pump oil is SAE20 or SAE30 non-detergent motor oil
Pump should be no more than 1/2 full of oil
Use plastic hose to drain pump oil
Do not turn machine on its side or turn machine over or engine oil will run into carburetor
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
I have excell 3700 pressure washer...the pump cover vibrated loose lost oil and cam melted.how do i get parts and change pum cam?
When you get down to it, purchacing oil end parts for a pressure washer is not cost effective.
The crank(cam) shaft runs about 280.00 dollars. The oil seals, new bearings, possibly new pistons and almost definatly new seals would be at least a hundred more. You can get a new pump for about 400 dollars and won't have to do all the work.
Dec 18, 2009 | Psi PowerBoss 20262 Pressure Washer
Pump with upgraded pump only getting half power
if you bought a new pump make sure its the correct type
then check for a unloader the adjustment part like a handle or an Allen screw on the head of the pump
dismantle grease up and replace
Aug 02, 2009 | Honda Pressure Washer PSI 3000
Excell VR2522 Pressure washer - sudden loss in pressure.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
No pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
May 22, 2009 | Karcher 2500 PSI Pressure Washer
Homelite For Excell - Pressure Washer Pump 2700 Psi 7/8" Shaft Logo
1,390 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Nick Olsen
Are you a Homelite Garden Expert? Answer questions, earn points and help others
