Question about Oreck 32 Type CC Xl Micro Filtration Vacuum Bags Fits All XL7 XL21 2000s 3000s 4000s 8000s 9000s series model Upright Vacuum Cleaners CCPK8DW CCPK8 PK80009DW PK80009 2000s 3000s 4000s 8000s 9000s XL7 XL200S XL21 XL-9100C XL-9200 XL-9300 XL-9400 XL9100HG SL
Need wiring diagram for Oreck XL9100 motor - Oreck 32 Type CC Xl Micro Filtration Vacuum Bags Fits All XL7 XL21 2000s 3000s 4000s 8000s 9000s series model Upright Vacuum Cleaners CCPK8DW CCPK8 PK80009DW PK80009 2000s 3000s 4000s 8000s 9000s XL7 XL200S XL21 XL-9100C XL-9200 XL-9300 XL-9400 XL9100HG SL
Posted by J BRISENDINE on
3 Related Answers
Anonymous
SOURCE: Oreck XL9100
Posted on Oct 06, 2008
Anonymous
  • 310 Answers
SOURCE: wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Wiring diagram Oreck XL2
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 09, 2008
Anonymous
  • 310 Answers
SOURCE: Oreck Orbiter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618779&thid=681757
Oreck Orbiter
Posted by eccott on Jun 18, 2008
Hi could you e-mail me a wiring diagram for the Oreck Orbiter please? I need to replace the mains cable & the cable to the motor. Thank you, Helen Eccott.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Orbiter Floor Machines ORB-500… you can contact the customer service line / tech support @ the Oreck Factory that I will list below for you and they will be happy to help or assist you in the wiring diagram, please include the model # and serial # with your request. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Posted on Jun 18, 2008
How do I wire an oreck xl9100 motor
The black wire coming from the power cord will go onto the terminal closest to where the cord goes into the vacuum. Sometimes there is a black dot next to the terminal. The white wire from the cord will attach to a piggy-back terminal on the white wire coming from the lights and will attach to the motor on the other side of the motor from where the black wire attached. There may also be a black dot beside that terminal as well. The black wire from the lights will attach to a terminal on the side where you attach the white wires, either right next to them or above them on the same side of the motor. Hope this helps you.
Sep 06, 2014 | Oreck Lamp Housing with Reflector XL9100...
My Oreck xl9100 stopped dead while plug still in wall. What now?
No smell or smoke? Then check outlet first (breaker?) Then open up and check for break in wire or loose connection
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Aug 30, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl9100 runs okay when upright but when the handle is at an angle the motor stops
you must test the power cord for open or break use the VOM
2) Test for main switch some wires loose, or bad solder, or switch defective, and replace.
3) Thermal fuse, loose, or bad contact. tight.
4) See if the belt is sliping or broke or worn and replace.
God bless you
Jul 27, 2012 | Vacuums
Hi, I appreciate your wiring diagram for the Oreck XL motor --but it is too small to read. Could you send me a readable copy. Thanks very much for your help! Nels Klyver
Print out the diagram u have, then scan it and blow it up to a larger size (all scanner allow u to enlarge the image), this is what I do with hard to read electrical diagrams.
Apr 28, 2009 | Vacuums
Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Orbiter
Oreck Orbiter
Go Ahead. Use Us.
Jun 18, 2008 | Oreck Orbiter Floor Machines ORB-500,...
I Need a Wire Diagram for my Oreck XL3600HH!!!
I emailed that diagram to you, hope it helps.
Apr 14, 2008 | Vacuums
Oreck 32 Type CC Xl Micro Filtration Vacuum Bags Fits All XL7 XL21 2000s 3000s 4000s 8000s 9000s series model Upright Vacuum Cleaners CCPK8DW CCPK8 PK80009DW PK80009 2000s 3000s 4000s 8000s 9000s XL7 XL200S XL21 XL-9100C XL-9200 XL-9300 XL-9400 XL9100HG SL Logo
1,594 people viewed this question
Top Oreck Vacuums Experts
Muntejaya Ginting
Muntejaya Ginting
john h
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
