Question about Kenmore Refrigerators
My freezer coil keeps freezing up. I replaced the
My freezer coil keeps freezing up. I replaced the timer for the defrost and have turned the switch many times to try to reset it but it seems to freeze back up every week causing my fridge to get warm
Posted by dwolf471 on
mike kirschbaum
    Genius:
  • 1,198 Answers
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Posted on Apr 29, 2009
5 Related Answers
Anonymous
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
Anonymous
  • 247 Answers
SOURCE: Freezer is freezing up.
Have a look at your door seals - if they're not airtight, the fridge will just suck in water vapour and freeze it. A.
Posted on Mar 25, 2007
Anonymous
SOURCE: I have an Amana Refrigerator Model # ARB2202CC
where is the defrost timer located?
Posted on Jun 23, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: I have an Amana fridge with bottom freezer that
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 16, 2009
Anonymous
  • 1891 Answers
SOURCE: coils in freezer - freezes up and the refrigerator
the timer tell it when to defrost but the defrost terminator and heaters must be working . ( you probley need the heater. and if so replace the terminator also .. mm
Posted on Jul 03, 2010
The fridge keeps freezing over
The evaporator coil is freezing, there could be a number of reasons.
a) drain line is clogged... defrost the fridge and shoot short bursts of compressed air into the drain to clear the clog
b) the defrost sensor on the evaporator coil is faulty... replace the sensor
c) the freezer is so PACKED as to impede air flow... stop stuffing your freezer
d) the defrost timer, defrost coil, etc. is faulty... replace as required
You could defrost your evaporator coil by turning off the fridge for several hours with the doors open, blow dryer, heat gun, etc... depending on skill level
True T72F defrost timer and lights not working?
You have done good work here young man. There is a relay or switch that is keeping the signal for being processed. I had the same similar problem with mine. At least your compressor is ok. Are you sure timer is wired back right.
Frigidaire side by side model # FRS20ZRGW3 coils freeze up on freezer side, fridge side gets warm
You have a defrost timer behind the front kick plate turn it clockwise slowly until compressor and fans stop. Once this happens the timer should remain off for 30 minutes and the defrost heater should come on during the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly should come out of defrost and the compressor and fans should restart, if not advance the timer clockwise until they start and replace timer. Try that first and tell me what your results are. If that is not the problem then we can narrow this down to the defrost heater=> 218657301 Defrost Heater or 5303917954 Defrost Thermostat How to test the defrost heater is found on same page as the defrost heater. If you have any questions I will be here to help you, Thanks Sea Breeze
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 • Freezers
1helpful
The freezer is freezing to the extreme fridge not cooling at all
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model also check the termination switch inline with the elements
2answers
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
3helpful
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
The coils inside the freezer behind the panel keep freezing solid. i have removed the panel and let them totaly defrost. is there something that needs to be reset to keep this from reacuring. ive defrost...
There is a defrost timer located inside your frig. When you open the door you will see a small housing on the top now look for a opening that has a screw driver flat blade looking switch. Take a flat screw driver and turn until you hear a click. That should be defrost cycle now wait 30 minutes and take note of the position of the screw you had moved earlier. If it has not moved the timer is bad and will need to be replaced. This is a old trick we do in the field to move into defrost and see if it was stuck or needs to be replaced. More then likely will need a new defrost timer. let me know how it all turns out. ken
1helpful
Freezer back panel freezes up
hi thanks for the question the problem you have is with either the defrost termination switch or the timer the defrost termination switch is located in freezer a small disc with 2 wires going to it replace this part thanks the appliance doc
Refrigerators Logo
Top Kenmore Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Carew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
