No power to lights, no compressor or fans. Power at the plug. Need help troubleshooting. Coils are clean, I'm stumped. Had a power outage 3 days ago, but refrigerator has been running until this morning. Need answer asap, if I need to call someone or replace need to know before food spoils too.
Do you know if you have a mechanical defrost. On the older side by side Amanda's there is the defrost control timer at the bottom in front. Put a screw driver in the slot and advance the timer. If it is stuck everything will be off. Think it's a small red dial. Open both doors, take off the front kick plate and it is under the front.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
SOURCE: Amana Temp Controls Stop Working - Show Dash - Food Spoiled
could be a glitch in the defrost cycle the adaptive defrost control could be faulty and when you unplugged it you might have reset it it should be ok till monday but i would just get the basics untill the tech looks at it
SOURCE: Our freezer is not cold, food is defrosting, ice
Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
SOURCE: Amana Refirgerator stops working for hours then starts again
check the defrost timer if necessary replace it
SOURCE: How do I install compressor for amana refrigerator
Hi.The compressor motor is connected to the refrigerant system, which is not user serviceable. It will be necessary to have the compressor serviced, or replaced by a qualified technician. During this process, the pressurized system will need to be re pressurized. This will require special tools, and regulative equipment, as well. This can be very dangerous, and that is why I prefer to give proper advise on this type of repair. Kindly, contact your nearest service tech.
Testimonial: "Thank you very much for your advice."
SOURCE: Amana ARB9059cs: compressor makes loud noise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
