How to clean lint trap
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
SOURCE: DEIX2 does not dry - cleaned out lint trap,
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
SOURCE: fisher paykel smartload dryer degxius does not dry
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
