Question about Invacare Supply Group Invacare Pronto M91 Electric Wheelchair
I have the tdx sp and the wrench light is flashing 7 times what does this mean?
Posted by scott parrish on
Specs Healthcare \ Avia Mobility
    Scholar:
  • 90 Answers
There is a problem with the remote joystick. Could be a bad connection or bad harness to the remote joystick. If harness is fine then the joystick has issues and needs to be replaced or rebuilt.
Try the 4-wire harness first.
Posted on Nov 14, 2013
Invacare TDX SP. how can I be sure it's charging? Should there be lighted indicator on control screen?
Not a specific charge light but the battery level lights should blink. If you have no lights that turn on on the joystick when you turn the joystick on then the chair is not charging, Do any lights turn on when you plug the charger into the chair then into the wall?
Feb 06, 2018 | Invacare Health & Beauty
My invacare tdx sp keeps flashing 5 error code it left wheel lock what is common reason for 5 flash
hi, Normally means the brake is in freewheel mode, you need to move the lever so it's in Drive mode then turn the chair back on ..
Regards
Sep 20, 2017 | Invacare Health & Beauty
HOW TO FIX: CHECK LIGHT & O/D LIGHT FLASHING -Won't go off!
You mean engine light is on,turn three times the on and off do not start car,should flash light...two times =2-3 means code 24
Dec 03, 2015 | 1994 Toyota Camry
What does 7 yellow flashing wrenches mean?
With most wheelchair electronics a 7 flash means the joystick is bad. A 7 flash means "joystick is out of neutral".
Sep 20, 2014 | Health & Beauty
Flash code list #7
Go to Pride's website to download the service manual. It has more information than the owner's manual does.
May 31, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Troubleshooting an invacare tdx sp electric wheelchair
Behind the drive wheels is a selenoid that has a flip up for "PUSH" and flip down for "DRIVE", make sure they are both in "DRIVE". That's what worked for me.
Oct 13, 2012 | Invacare Health & Beauty
Hi, I droped my SP-320 yesterday and now i can't turn it on. The red and green light is flashing. What does the flashing lights means? Joe
I have the same problem with flashing red and green light when I tried to turn on my Olympus SP-350.
I don't know what's wrong, so please let me know if you have any clue. I personally did not drop the cam, but someone else might and did not tell me :(
May 25, 2011 | Olympus SP-350 Digital Camera
The joystick on my TDX wont make the chair move and a key insignia flashes. Battery is fully charged and the other controls ( chair tilt and footplate lifts all work OK. What can the possible problems be...
count the number of flashes of the wrench and it will tell you what the error is. ie 4 falshes right motor Your owners manual should have the flash codes in it and will explain the error you are having Hope this helps
Feb 27, 2011 | Invacare Health & Beauty
My jazzy select 14 on the controler near the joystick lights up what looks like a yellow wrench in a 9 flash. Lights 9 times stops then lights nine more times over and over . please help
well a wrench means the obvious that something needs adjusting , if it came with an instruction manual search for the code 9 blinks will mean.
Oct 16, 2010 | Pride Mobility Products Jazzy Select 14
Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Logo
568 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
