Question about Toshiba 26HL83 26 in. LCD HDTV
TV suddenly stopped working; not will not power up at all.
My TV worked just fine for a few months, then one day, it suddenly shut itself down. This lasted for about a 1/2 hour, then I was able to turn it back on. It continued to happen, with increasingly longer periods that it would not operate until, finally, it stopped working completely. Any ideas?
  • 393 Answers
It may have overheated
or it blew a internal fuse
if this is the case you may be covered under warranty. if warranty is expired contact
http://www.tacp.toshiba.com/customersupport/contact.asp
Posted on Apr 29, 2009
I have a new Comfort Aire RAD-101. From time to time it would just stop working and then turn back on after a few minutes. Any ideas as to what causes this, A/C is installed in the Caribbean?
my option before it is to late is to remove the cover and clean out the blower as it could have a lot of junk there causing the blower motor to over heat and shut down.
Oct 02, 2018 | Cars & Trucks
My remote control for my Pro View TV suddenly quit working. Is it fixable or, if not, how can I get a new one?
The replacement batteries could be defective or installed incorrectly. If the remote cannot be revived, you can search online for several providers of replacement OEM remotes.
Feb 28, 2015 | Televison & Video
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
My Bauknecht dishwasher stopped working
Check all your breakers. Remove the wall plug, count to 20 and plug it back in and count to 5. This will reset it.
Jul 17, 2017 | Bauknecht 24 in. GSFP3988 Built-in...
Won't turn on
my orion tv is not working,it just stopped
Apr 29, 2008 | Televison & Video
Laptop goes off
If a computer shuts itself down suddenly after 10-15 minutes it's usually down to oveheating. clean the filters and ensure that there is good airflow around the computer when you use it. you can keep an eye on temperature and control your fans with this program
http://www.almico.com/sfdownload.php
you might need to buy a laptop cooler like this
http://www.amazon.com/Targus-PA248U-Notebook-Chill-Pad/dp/B0000AKA8Y/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1204562271&sr=8-1
which sits underneath it and blows cool air in
Mar 03, 2008 | Acer Aspire 5630 Notebook
T.V. shuts off
try unplugging it from the wall for a day
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 06, 2008 | Panasonic PV-C1321 13 in. TV/VCR Combo
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
Toshiba 26HL83 26 in. LCD HDTV Logo
620 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
