Question about Mitac Mio 168 Pocket PC
Usb driver - Mitac Mio 168 Pocket PC
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
Drivers usb install correct but when i use any USB device it not reconogzite
Please uninstall the usb drivers. goto run -> devmgmt.msc -> USB controllers- > uninstall the drivers.
Then run the CHIPSET drivers of your motherboard by running the setup from motherboard CD.
If you dont ahve Motherboard CD, goto link below
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Download the USB drivers for windows xp is :
http://download.ecsusa.com/dlfileecs/driver/mb/usb/via/via244_xp.zip
Install it.
Even the usb devices are not working.. goto BIOS by pressign DEL key or F2 on power on the pc. Check USB Drivers are DISABLED. if disabled, please Enable it.
Use the Back side USB connectors if the front usb are not wokring..
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jul 01, 2011 | EliteGroup P4VMM2 Motherboard
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Vista software driver for usb cable
You can find 2.0 USB drivers at www.intel.com but Vista comes with USB drivers built in. If you're having trouble seeing a device that you plug in with a USB cable it's probably not the drivers for your USB port but a problem with the periferal that you're plugging in.
Nov 29, 2009 | Plumbing
Usb driver software needed for nokia 3500c model
http://www.nokia.co.in/link?cid=PLAIN_TEXT_406563 =)
May 23, 2009 | Cell Phones
USB CABLE
the printer is designed to work with a parallel cabel connection. usb to parallel conversion cables may or may not work.
now for the second part is, about the driver (visit manufacturers website for updated drivers), usb driver behaves differently compared to parallel drivers as it expects a usb printer connected to a computer. try both drivers. remember, it may or may not work.
Dec 03, 2008 | Argox OS-203 Thermal Label Printer
Nokia siemens ADSL Modem c2110 USB Driver
if u want Nokia siemens ADSL Modem c2110 USB Driver then reply me at [email protected] the driver is working great in windows 7.
Nov 01, 2008 | Computers & Internet
How can i download usb driver form ADSL Modem c2110 i want to down load the siemens c2110 usb modem driver.Please help me.
Sep 29, 2008 | Computers & Internet
USB driver
I want U S B driver for SIEMENS Modem C2110
Dec 16, 2007 | Interlink EPAD USB SGL PK-W/DRIVER ONLY...
Mitac Mio 168 Pocket PC Logo
Top Mitac Computers & Internet Experts
matt
matt
Tom Chichester
Larry Ng
Larry Ng
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
