Question about Dell XPS M1210 Notebook
Dell XPS LCD problem
On boot up my LCd is fine on my laptop, after a few minutes it starts to go crazy with screen distortion. is this a Grapics card or lcd problem? and howe can i fix it so it wont cost me a arm and a leg?
Posted by jim_mclendon on
  • 3 more comments
  • jim_mclendon Apr 30, 2009
    My laptop was heating up but i had a chill mat under it which kept the heating to a minimum, I checked my drivers and they were up to date, I started it in safe mode with the same results. I have since used an external monitor and came to the conclusion that the problem is with my LCD and not with my mother board. After reading alot of forums on this issue the only thing I can do is replace the LCD or use another monitor.
    If you have any other suggestions on how to solve this other than LCD replacement, I am all ears.
  • Anonymous Apr 30, 2009
    I tried moving the screen back and forth and there was no change. I guess I could check the connection. I will get back with you to see if that works
  • Barry Parks May 11, 2010
    Have you run the Dell Diagnostics tests on the system? If not, try this:
    1. Power off the laptop
    2. Hold down the 'Fn' key and press the power button. It will start ind diags mode.
    3. Watch for the color bars to appear and press 'y'.
    4. Note all error codes that reported.
    If you see the color bars, the screen should be all right. The issue could be the video card, BIOS flash or video drivers.
    Let me know what you find and I'll try to help you.
    ~ Spoem
  • Anonymous May 11, 2010
    Does moving the screen have any effect on the problem?
    The only other thing I can think of is possibly a connection problem, the easiest to get to is the main connector. Remove the piece between the keyboard and LCD, the main connector should be visable then. I would disconnect it and reconnect to see if that helps.
    The other ones are not so easy to get to, you have to remove the front plastic from the LCD, then remove the panel to get to the back of it. You have to decide if this is something you want to try.
    Is it a heat problem? Is the laptop getting hot anywhere?
    Have you updated the video drivers? (possible but doubt this is it)
    Start the computer in safe mode, by pressing the f8 key duing boot and selecting safe mode. Does it still happen?
Anonymous
  • 52 Answers
If the distortion happens inside windows, this is a graphics driver issue but, on the other hand, if this happens before Windows or outside Windows, this is a video card problem
Posted on Jun 10, 2009
Anonymous
Uninstalling and reinstalling the video card drivers did the trick for me. this was done in windows, not Safe mode. i got the back light to come on by pressing the power button a couple times, this simulated sleep & wake-up.
Posted on Nov 11, 2009
XPS Gen2 / M170 display issue, mind boggling
What are the BIOS versions and what are the mother board revision numbers?
Mar 10, 2014 | Dell XPS M170 Notebook
Hi i recently started having problems with my dell inspiron 1545 screen. At first it started to freeze and fade to bright white, eventually after a few days it became stuck white even after booting the...
Hi lewis haywar,
Try to replace the LCD inverter in your laptop. Most common issues on LCD are due to failing LCD inverter. It fails more often than LCD cable or LCD backlight does.
Please let me know if this solution helped to resolve your issue.
May 11, 2011 | Dell Inspiron 1545 Notebook
Horizontall lines appear on the screen on booting screen gets discoloured for a short while
RUN the LCD BIST test D+Power button at boot, see if you get 4 solid colored screens
If you do then the video processor is failing. This means replacing the motherboard.
If issue occurs during the BIST, then the LCD is failing and LCD will need replacement.
Jun 25, 2010 | Dell XPS M1530 Laptop
Have dell xps one that white screens. it boots to windows cause you can hear music. changed out to working video card but dont know if lcd is next step or motherboard??
their might 2 problem, check vga cable or replace it and after that it does not work then thier is a issue with LCD need to replace.
Jun 08, 2010 | Dell XPS One All-in-One TV Desktop with...
Display problems with dell xps m1530 laptop
These models have known video card problems, so first thing connect an external monitor before booting - boot and see if the image on the external monitor stays on, if it's fine on the external monitor then the LCD panel might be defective, otherwise if you see blurred / distorted image on the external display it's the VGA card. which means you should contact warranty (if you still have) because the mainboard needs servicing / replacement.
May 25, 2010 | Dell XPS M1530 Laptop
Hi, I have a dell inspiron 5100. I have two problems. 1) My screen is completely black and I have to use an external monitor. When I start my laptop, I can see the Dell Logo and after that is when...
for your video problem, you may be stuck in a different mode try holding the Fn key and hit F8 this toggles through the modes
1 - LCD on laptop only
2 - LCD and external Monitor
3 - External monitor Only
if this does not work you may have a LCD issue with the laptop .. let me know how it goes first
Feb 02, 2010 | Dell Inspiron 5100 Laptop
When my xps m140 laptop boot up after few minite lcd screen blak out. how to fic this?
There could either be a problem on your LCD screen, or Graphics card, to determine it. Try plugging an external monitor on your laptop and see if the display turns black also on the other monitor. If no, the problem is the LCD, but if yes (still black screen on the external monitor) it means the problem is on the graphics card.
Dec 15, 2009 | Dell Inspiron XPS M140 Notebook
Dell m1710 xps will not boot, grey screen only. battery light, num lock lights work and hd lighyt flashes momentarly, then goes off.
Are you certain the laptop is not booting? I had one the other day, customer thought it wasnt booting, but it was the LCD screen that was bad. She had only a gray screen too. Something to try, with the screen up, put your hand on the top of the LCD (fingers on the plastics on the back side, thumb on the screen at about the same position) about 4-5 inches from the left edge and squeeze gently. Does the screen change at all, vertical or horizontal color lines? If it really is NOT booting, try F12 when first powering up and if you get to the boot menu, choose diagnostics, run them and see if you get any errors.
Aug 09, 2009 | Dell Inspiron XPS M1710 Notebook
Dell XPS M1330 PC problems when turning on
Faulty LCD Inverters were causing similar power problems on dell laptops. if you know how you can remove the lcd screen and try run it on an external monitor, if it works, replace the LCD Inverter.
Dec 23, 2008 | Dell XPS M1330 Notebook
Dell XPS M1210 Notebook Logo
979 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
