Question about HEWLETT-PACKARD LASERJET PRO P1606DN PRINTER
Hp laserjet P1606dn network adapter: no green
Hp laserjet P1606dn network adapter: no green light or hub what's up?
Posted by joe martin on
Russ Hill
  • HEWLETT-PACKARD Master
  • 4,057 Answers
Is it red... if no colour the wifi card has either come loose or not working any more.
Posted on Nov 03, 2013
CE749A not discovered during install
Verify that the network station cable (the one connected to the P1606DN printer) is good and that the connection to the network is good. You can do using a number of methods. But, if you have a portable computer, the simplest method is to disconnect the cable from the P1606DN, connect it to your computer (make sure the wireless on your computer is turned off), and verify that you can connect to your network. If not, you have a cable/network problem.
Otherwise, try resetting your P1606DN printer to its factory defaults:
1. Turn off the printer
2. Turn the printer back on, and while it is initializing press and hold both control-panel buttons at the same time until all the lights blink in unison.
Then put your static IP address back on the printer and hopefully you can now connect. If not, can you ping it from a workstation? If not, the network adapter circuitry in the printer may have failed.
Feb 02, 2014 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Hi, We have installed HP laserjet Pro1606dn as network printer, however print action does not until printer in switched off or out of paper
Delete the software and Re-install from the server, if this does not stop. Try printing directly ( via USB) to be sure its not the Formatter.
Mar 15, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
IS there a way to extend HP P1606DN PRINTER toner a little longer?
In the settings menu there should be a economy mode. Change to that mode.
Mar 13, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
HP LASERJET P1606DN goes to offline
Happened on our print server this morning for the first time. We have 4 of 1606dn in our organization. Reset the print spooler and that brought it out of offline mode
Jan 09, 2012 | HEWLETT-PACKARD LASERJET PRO P1606DN...
My HP P2015n won't connect properly to my home network
I'm afraid the formatter pcb is defect. You will have to replace it. Partnumber Q7805-69003.
Feb 14, 2010 | HP LaserJet P2015n Printer
HEWLETT-PACKARD LASERJET PRO P1606DN PRINTER Logo
101 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
George Mclaughlin
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
