On start up of LG 42LC7D, i usually have to turn on and off multiple times for the screen to put pic out. I get a green light and a black screen, unless I turn on and off 4-10 times
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
SOURCE: I have the exact same issue as the unsolved
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
SOURCE: LG 42LC7D.......Have sound but no
It sounds like you have a logic board problem. It is easy to fix open up your tv on the back and the logic board should be covered with a small metal plate unscrew the it, it uses small screws get the number of that board an order it through guytvparts.com is the cheapest
There are some capacitors on the main boardthat are low quality. You can buy a capacitor repair kit on Ebay that contains a set of capacitors to replace the offending ones - about 15-16 bucks. I soldered in the new capacitors and the TV has worked perfectly since.
