HP PAVILION A6230N DESKTOP PC Logo
C
Connie Wiener Posted on Nov 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Pavilion a6230n with Vista - 1 short beep followed by one long beep repetitively and will not boot at all. The beeping pattern continues indefinitely.
Lars Olsson
Level 3:
Brigadier General:
  • HP Master 3,400 Answers
  • Posted on Nov 02, 2013
Lars Olsson
HP Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1049096
Points
10330
3 Related Answers
Anonymous
  • 492 Answers
  • Posted on Jan 07, 2009
SOURCE: 2 beeps on HP Pavilion a1600n
It all depends on your bios type.  Here is some more information for you to reveiw. http://en.kioskea.net/contents/pc/bios.php3
Anonymous
  • 5158 Answers
  • Posted on Jan 26, 2009
SOURCE: Computer gives 1 loud continuous beep on startup
unplug your memory and reseat it... that should fix the issue
Robert
Please take a moment to rate this solution.. thanks
Anonymous
  • 287 Answers
  • Posted on Jan 02, 2010
SOURCE: I have a hp pavilion elite m9040n. It will not startup
It may be a RAM problem...try these steps :
1. Remove the RAM from the slot.
2. Install it properly in the slot.
3. Start the system!
tell me if it helps...! :)
Acer x1300 Will Not Boot. Continuous Short Beeps, no pattern, just repetitive short beeps evenly spaced. No display on monitor. I have already replaced the motherboard with a spare.
check ram and other peripherals. If not those then the CPU may not be seated properly or you may have forgot to put thermal paste between the cpu and heatsync
hope this helps
OS Vista. 2 short and 1 long beep repetitive - will not boot at all.
2 short beeps and 1 long beep (repeats 5 times)
Unable to initialize video or video card required but not installed.
if you have a video board add on card, reseat after unplugging power cord.
If built in, time for new computer
2helpful
3answers
Pc won't boot, just beeping
firt well try the easiest solution.... did u take out the cmos battery on the board for a few minutes, put back in and try again. of course, unplug your computer before u do this. is there a beep pattern?, how many beeps...
1helpful
PC will not boot up. Almost did once but screen went black. Reboot doesn't help. No green light on monitor and PC makes a long slow beep over and over. I have recovery discs but when put it nothing...
Based on your description of your problem, my educated guess is that you have a problem with the system board or motherboard. Checking Compaq support site, it says that beeps are generally heard when a hardware device is not connected properly or has failed.
First thing to try is disconnect the keybaord and mouse and try to start the computer again. What we are trying to do is find out which hardware device might be involved. So start with the keyboard an mouse. If the computer still does not start, remove any periferal drives, like floppy or cd drives.
There are several beep codes, below are a few examples listed:
Beep codes common to HP and Compaq Desktop PCs The following beep codes are common to many HP and Compaq desktop computers. Use these codes first before referring to the other code lists. NOTE: Not all codes are shown. Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful Try working on this solution and see if you can get the computer to start. Below is a link to a troubleshooting page from Compaq for your computer. This can be a good reference as well.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899280&tmp_task=solveCategory&lc=en&dlc=en&cc=us&dest_page=solveCategory&tool=solveCategory&query=pavilion%20m8200n&product=3548185
I hope that this information was helpful.
Brian
When I turn my HP Pavillion on, it makes 1 long 15 second beep then about 5-10 seconds of silence then another 15 second long beep. It does this continuously. There is nothing coming up on screen at...
If not solved yet, make sure the fan is spinning on the heat sink on the processor. If it is, then if you have a video card installed, make sure that fan is spinning. These are 2 pieces of hardware that will cause the beeping and shut down.
Pc beeps and will not come up
The beeps you are receiving are called "BIOS beep codes." You can look what the beep code indicates from here for HP:
h10025.www1.hp.com/ewfrf/wc/document?docname=bph07107
2answers
HP pavillion DV 2000 cant boot and with 1 long 2 short beep
I found some info on a forum, it says the 1 long and 2 short beeps is a problem with the graphics chip. You may need a replacement motherboard.
Check this post out
http://www.computing.net/answers/hardware/1-long-2-short-beeps-hp-laptop-/52894.html
I have a HP Pavillion DV 2000 laptop with me. When i boot my system it gives 1 long beep followed by two short beeps and the system doesnt boot. I am not sure as what to do. Can someone help me here?
This website:
http://www.pchell.com/hardware/beepcodes.shtml
Lists standard beep codes for computers. The one long, followed by two short beeps indicates a display problem according to the site.
I have heard other people say that the same beep codes specify a RAM problem.
Have you recently installed any new RAM or a new graphics card, or made changes to either.
It seems likely to be the graphics card because of the missing info on the screen. Usually when RAM is bad there is something on the screen.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
