SOURCE: WATER LEAKING INSIDE
We had that happening in ours, and so we redistributed the items on the top shelf, The things were stacked high, and though the refridgerator was ok, the coldness wasnt able to circulate like it is meant to do.
SOURCE: Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
