SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
SOURCE: MY GAS OVEN TOOK 2 HOURS TO REACH THE DESIRED TEMPERATURE OF 350.
the ignitor is prolly bad (not pulling enough amps)
SOURCE: Probe prevents oven from reaching desired temperature
if you had to sandpaper this probe, then this is yoru initial problem, do the right thing and replace the probe with a new probe
Okay
SOURCE: The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
