Samsung RS2630SH Side by Side Refrigerator Logo
B
Barry Richardson Posted on Nov 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashing freezer led
LED stopped displaying one small section only flashing
Tom Zwiebel
Level 2:
  • Expert 318 Answers
  • Posted on Nov 03, 2013
Tom Zwiebel
Expert
Level 2:
Answers
318
Questions
Helped
157206
Points
933
A flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
2answers
The display on sole F63 treadmill not working (no lights)?
check any damage on the display board and inspect the wiring
I have a delta touch faucet and the blue led light stopped working. The red is still lighting and the touch feature is working properly. How can I fix the blue led light?
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
1helpful
Lights on fridge and freezer side won't stop flickering. It's like a disco strobe. Ideas what needs to be fixed?
The led control needs to be replaced. This part is located and part of the upper main led in the refrigerator section or a board located in the back by the compressor. This is a separate board and not part of the main control board.
1helpful
3answers
How to stop the flashing (strobing) lights inside both the fridge and freezer?
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
It won't sync
Click on the USB small button "after attach it to the computer" one click. While the red tiny led flashing - turn your mouse updown and hit the small button.
When the red flashing led stop - then you connected.
GE fridge PDS22MBSWW - relay clicks on and off
sounds like a main control...check the fans ... unplug each on at a time to check if the relay will stop clicking...
Jvc hd61z575 61in. rear projection tv won't come on
ok you have defective power supply in hotside section! maybe they have abnormal oscillation!
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
