Question about Brother HL-2170W Laser Printer
Won't print I just bought this system 2/23/07-it says on the bottom idon it is sleep, toner is low {which should not be the case as it is new, in a home office of a 75 year old who does NOT print that much. No instructions, I cannot remove the toner. How does that work and why is there no instructions included with item? I am aware I could go on line and print one off IF the dam printer worked.
Posted by mccowell1 on
Paul Hutchinson
  • 909 Answers
You can also save the PDF file on your pc and read off the monitor.
Posted on Apr 29, 2009
Bizhub350 toner not feeding
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 05, 2017 | Minolta bizhub 350 Black and White Copier
I was changing the toner of Konica Minolta biz hub 163, and it shows a message that reads service call C0070. Please, what will I do to continue my work?
Sir/Mam,
Jul 13, 2016 | Konica Minolta Office Equipment & Supplies
is this a Minolta Di470?
If so try this:
Apr 28, 2014 | Konica Minolta Office Equipment & Supplies
How to reset toner
Sir/Mam,
Nov 30, 2013 | Konica Minolta DiALTA Di200 Copier
Mi maquina sale en codigo c0072, ya el tecnico cambio el motor del motor pero saque 120 copias y vuelve a salir el codigo c0072, no se que hacer.
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner install it correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
if parts are required try this site as a start
if parts are require Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 04, 2011 | Minolta EP4000/5000 CS/PRO Copier
Dear sir, my toshiba e studio machine some time showing "dispose used toner" . I thing that means tonner is finished. there have 4+1 toner which we need to replaces Idon,t know. Please help me
Dear,
your copier e-studio 350 some time showing '' dispose used toner'' It dont mean you install new toner... its mean you dispose used toner box.. Dear open the copier frant cover
and dispose used toner white box...
Thanks
Best Regards,
Aug 05, 2010 | Toshiba e-Studio 350 Copier
Microsoft office 2007 Home Student program tells me that the microsoft product key on the label on the bottom of my brand new acer aspire one is incorrect. What do I do now?
Are you sure you're not entering the key from Windows? That sticker would be on the bottom.
Typically, the product key for MS Office is on a separate card in the documentation that came with your computer. If that's not the case, call the store you bought the computer from or call Acer Customer Service for assistance and don't give up until you get it resolved. Microsoft may also be a good resource.
Oct 20, 2009 | Microsoft Office Home and Student 2007...
Toner empty message
I would try to unplug the printer and leave off for a few minutes. and see if that resolves the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Toner low???
How is the copy quality? Are copies light? If so then the toner hopper is not adding toner to the developer assembly in which case you must call a tech. If the copies are fine then the toner sensor is dirty or faulty and must be replaced.
Jul 11, 2008 | Canon 3045 Black and White Copier
Brother HL-2170W Laser Printer Logo
186 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
