Question about Samsung ES30 Digital Camera
I am unable to take photo because of DCF full Erros come often ES30
Posted by kloh thoo on
Harrie
    Top Expert:
  • Samsung Master
  • 6,746 Answers
This is what the manual says:
File names do not match the DCF standard.
Transfer the files on the memory card to your
computer, and then format the card. (p. 76)
Format in the camera, not in a cardslot of your computer.
Lots of errors, can be solved by removing and reinserting the battery(ies)
Posted on Nov 06, 2013
1 Related Answer
Anonymous
SOURCE: DCF Full Error
I have got a Samsung ES30 Digital camera .Everytime i turn it on it always says DCF Full Error ' which i have no idea means .Please help???
Posted on Dec 29, 2010
I lost my cd for samsung es30 to transfer photos from the camera to pc how to download and install from net get me web adds
Get an external SD card reader/writer. They range from 3.00 to 13.00 US. It makes transferring photos way faster than using the cable that came with the camera. Photo's load directly to your hard drive so photo editing is easier.
Oct 01, 2014 | Samsung ES30 Digital Camera
My Samsung ES30 camera gives me the DCF Full error message.I tried other solutions ,such as formatting the memory cardd,I even tried a new memory card.Still the message comeup.Who know what to do?I am in...
The manual says: the files names does not match the DCF format. Transfer the files on the card to your computer and format the card.
You tried to format and it did not work. Sure the card is not locked? The lock switch should be up, so the card is unlocked an you must be able to format te card and you should be able to write files to the memory card.
Although the camera is compatible with SCHC I wonder if you did not put in a very big card. Perhaps your camera cant work with 8 or 16 GB. Is surely can't work with SDXC cards.
Did you try a normal SD card, and could you format that one?
Nov 02, 2013 | Samsung Cameras
DCF FUL EROR YAZI VAR NE YAPMALIYIM
Format your SD card on your samsung camera.
Thanks for using fixya!
May 28, 2011 | Samsung ES30 Digital Camera
When l take my SD card, it still says " DCF Full Error"
Hello and Welcome
The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You will have to format the card with the Samsung camera.However, make sure you download any photos to your computer first
Anymore help, I am here to help
Best of Luck
Concerned:
Uxair Shah
Mar 14, 2011 | Samsung ES30 Digital Camera
When I take my SD card out, it still says "DCF
well as long as it works when u put the sd card in then its all good right?
also
  1. DCF Full Error error message. The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You'll have to format the card with the Samsung camera. However, make sure you download any photos to your computer first.
Mar 07, 2011 | Samsung ES30 Digital Camera
Our Samsung ES30 is showing a DCF Full Error. It is only 1 month old and has a 2gig SD card in it. What is the problem?
.try to format both...
remove the sd card on your unit,then insert that to the mmc reader then format it to your pc,,after formatted.,,
open your unit without sd card,,go to menu - setting - format -reset
after that insert it to your unit.,then take atleast 15 shots.,.then turn it off.,.,then open again for you to find out if this procedure will okey.,
Feb 23, 2011 | Cameras
My Samsung ES30 camera gives me the DCF Full Error message. I tried other solutions, such as formatting the memory card, I even tried a new memory card. I also tried drying the inside, with the batteries...
try to remove the memory card and then format the unit without memory card.,after formatting the unit.,reset it and then format the mmc to the pc.,after 10 seconds.,insert the mmc and then power on again.,
Jan 16, 2011 | Samsung Cameras
Tl220
camera and or card memory is full?
change card or download photos to computer or other media and delete from the card in the camera to make space for new photos.
Oct 22, 2009 | Samsung L200 Digital Camera
Unable to resolve 'cartridge has been changed' error message
turns out the wrong paper size was selected in the print setup. I set it to Postcard (4x6) and it began working perfectly again. Hooray.
Jun 01, 2009 | Canon SELPHY ES30 Thermal Photo Printer
DCF Full Error
Sep 25, 2008 | Samsung S860 Digital Camera
Samsung ES30 Digital Camera Logo
108 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
