I have a emachines 820 and just changed the power supply unit but now i cant turn the pc on .when i try and turn it you can hear a clicking noise from in side . can anyone help or have had this befor
Posted by markhutch101 on
  • Michelle Crabbe May 11, 2010
    You will want to check and ensure that the power supply is of the correct power. For older model boards 250 watt power supply is needed. If its a 300 watt power supply then you should have a newer board. Further more, make sure that if you are using a surge protector that it is up to date. From experience, older power bars can blow up a brand new power supply. Check the back of the power supply to see if there is a switch. Some provide an option of 115v and 250v that may be an issue as well. If you can provide more information on what is happening I might be able to provide more information for you.
SmartAviator
    Sergeant:
  • 449 Answers
It is possible that a wire is touching the CPU or Power Supply cooling fan. ([email protected])
Posted on Jul 18, 2009
Tv wont turn on, and its making a clicking noise
That usually indicates that your power supply has gone bad. The clicking sound you hear is your power supply not getting enough current to turn on your screen. Could be a simple fix as a bad capacitor but not sure? If you can pin point that problem being your power supply, it is some times cheaper to just replace the power supply board but it depends how old your TV is and if the power supply unit is available.
Feb 23, 2015 | Televison & Video
I have a emachines 820 and the power supply unit went so i get a new one and replaced it but now my pc will not turn on the info i have on the hard drivers is there any way of saving it or have i lost...
you have not lost everything, the first thing you want to do is to confirm that all is plugged in properly with new PWR supply, newer supplies have a yellow and black power cable coming from them that is part of powering your motherboard, if needed there will be a little plug near the CPU somewhere that it will go in, short of that being your problem, you will have to move HDD to another computer as a slave and retrieve your data that way
Apr 29, 2009 | Computers & Internet
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
No power on my emachine
Open the machine - try to change the SMPS.
Hope the Power-oN button is not the problem.
Else there could be many reasons.
Dec 17, 2008 | E-Machines eMachines Refurbished EMA...
Emachine power supply
Unfortunately, E-Machines are well known for their power supply problems. I have a room full of them.
Let me guess, you can hear something rattling around in the power supply, right?
When this happens, a component blows cleanly off of the board inside, and sends a voltage spike to the mainboard.
With any luck, the hard drive logic board wasn't damage, and you can recover your data with another PC.
Apr 25, 2008 | E-Machines eMachines Desktop PC
TECNIK TDK 795 FAULT
is there the power supply still to the washer??
Mar 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Pc won't turn on
Hi, Are you able to test or repair some of this your self? is so use a multimeter and check the power supply,If you get no reading then remove the unit and open the cover, on the printed circut you will find a fuse either glass or ceramic. Replace this and also clean all dust from the unit replace the cover and reinstall in computer. If this fails you may need a new power supply unit. Regards mistyman
Sep 07, 2007 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Computers & Internet Logo
120 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
