Question about Cambridge Audio Azur 640A Amplifier
I cannot open my cambridge audio 640A compact disc tray
This is a common issue with all belt-drive cd players, all you have to do is to change that belt and you should be done, or take it to a shop for servicing, as this is a part of a simple service maintenance routine, cheap fix though.
Posted on Nov 08, 2013
SOURCE: 230 Voltage
Good Day sir, yes the 640a has a voltage selector switch.
http://www.cambridgeaudio.com/support_products.php?PID=105&Title=Support
Hope this may help.
Posted on Jul 21, 2009
SOURCE: Hello,
Why don't you try using the main outputs (the 2 XLR connectors). With 2 cables connect these two (left - right) outputs at your amplifier's aux in. In that case take care that the "output level" of the mixer works like master volume controlfor the signal that the mixer sends to the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 25, 2010
SOURCE: i have a cambridge 640a
audio amplifier IC´s damaged need to be replaced
Posted on Sep 24, 2010
SOURCE: HI, Can the Cambridge Audio 640a integrated amp
Of course, just run an audio RCA pair out from the Pre Out to your next amp and any input. All control for volume, tone, etc will remain with the 640A.
Posted on Jan 26, 2011
Testimonial: "Thank you. How will I connect my sub woofer though?"
SOURCE: cambridge azur amp 640a working
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
Posted on Mar 06, 2011
