Checking your autorun applications may help. There may be a process like Norton Antivirus that is preventing the system from shutdown. Start by following the previous instructions to press F8 on startup, start safemode, then shut down as see if the issue remains. If so it's likely a hardware issue. If it does shut down normally get a program called "autoruns" it's hosted by the microsoft technet team and will list everything starting with windows. Review the results after opening it on a normal system restart and start by a process of elimination to find which program is locking up the system.
There is one solution that you can do, you can hold the power button for about 10 seconds and this will shut your computer down, this is known as a hard shut down. My question would be how often does this happen? If it happens at every shutdown I would recommend scanning your computer for viruses and malware. If that doesn't fix the problem I would recommend backing up your data and restore your operating system.
SOURCE: DELL MASTER RESET?????
When booting up to Win XP you may get a error that reads "Unmountable Boot Volume". This is probably because your boot.ini file is messed up.
You should be able to restore your windows installation.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&l=en&s=gen&docid=35F157CB59994ED7E040A68F5B2813E3&journalid=4391620012FE791FE040A68F73281D77&Query=dW5tb3VudGFibGU=&SystemID=DIM_CEL_1100&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
SOURCE: Dell Dimension 2350 restore cd or bootable cd.
go to pricegrabber.com to buy a new copy of XP. Save the stuff U want and install the new os. reload U'r saved data. If some of what U wnat to save are programs, U will have to reinstall those. The new XP os will self install from cd on boot up.
SOURCE: Hard drive size in a Dell Dimension 4700
nope, have one here that I put a Terabyte drive in and it is working great.
SOURCE: My Dell Dimension 4400 running
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
SOURCE: My Dell Dimension 2350 will start-up and show the
Please restart >prees F8>seclect last known good configaration by your up and down arrow key
and hit
hope it will help you
