Question about Microsoft Xbox 360 Controller
I have two wireless controlers that wont sync with my console when i push the sync button i have also tried using a play and charge kit and it still dont work but my wired rock band guitar and drum controlers will connect.
Posted by sixmudvayne6 on
Anonymous
    Problem Solver:
  • 4 Answers
It could be what is called an RF board its located just behind the ring of light you will need to probably buy a new one maybe on ebay its cheap enough, also to replace this RF board you will need to open your xbox 360 which will void your warranty!
Posted on Jun 06, 2009
Anonymous
  • 62 Answers
When your are syncing put the controllers next to the IR recievers on the xbox that should do it
Posted on Apr 29, 2009
Anonymous
Click the button on the front of the 360 console... which is to the right of hte memory slots... when the ring of light is spinning around click the button on the top of the controller... it will then connect to that system. There after it will always look for that system. so if you want to connect to a new system you push the button on the front of the system and then the button on top of the controller.....
Posted on Jun 09, 2009
Anonymous
That wont make a difference because the pads arent IR, they are RF. So as long as they are in range they should be found.
Posted on Jun 07, 2009
Cannot get my xbox360 and rapala rod to connect wirelessly
1. Ensure Batteries are good.
2. Review the "xbox360 Controller sync procedure" on YouTube.
3. Find the sync button on the Rapala Rod. (small white button) Push it and push the controller sync button on the console.
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
My xbox 360 wireless controller is new and the green light just keeps falshing it will not go on to 1 or 2 player.
you may have to sync your controller to your xbox. First you hold the big X button in the middle to turn the controller on. Next, after making sure your 360 is turned on, push the sync button on the 360 controller so the lights around the big X are spinning around. you will find it located at the top of your control close tp LB (it has 3 little waves next to it) Finally, push the sync button on the 360( which is located directly to the right of memory unit B or with xbox360 s nex to the part at the front with 2 usb ports) and the lights around the on/off button of the console should spin. Eventually, your console will find the controller. hope this helps
Wireless controllers wont work lights just keep flashing
Have you tried syncing the controllers to the XBOX?
On the front of the xbox there should be a small button next to the memory slots. push that and then push the small button at the back of the controller (near the port). After a few seconds, the controllers should connect.
Good Luck!
Install wireless racing wheel no software
This will sync up just like a regular wireless controller. I have one of these. There is a small button on the fron of the console under the memory card port. This is the sync button. Push it and the lights will go around the ring of light on the 360. now find the small button on the racing wheel and push it while the xbox is in sync mode. When the link up the 1th controller light will light up.
The wheel works great it has force feedback which means the wheel will react to road conditions. If you hit a curb in a game the wheel will **** on its own just like a real car!!
1helpful
My Wireless controller is not being recognized by my console, when i turn on the controller it blinks repeatedly, what can I do?
Try using the sync button. Push the sync button on the xbox, then on the controller.
If that doesnt work, get a cord and plug it into the console. One it is connected you can unplug it and shouldnt have anymore problems.
2helpful
Xbox wont sync with my wireless contorller
Have you ever synced one of these controllers before?
Hold the controller in your hand as if you were playing a game. Next flip the controller up so that the buttons on it, are facing you.
There is a small white button that you will see. Power your xbox up and after you get to your main menu press the sync button located about 2 inches to the left of your main power button on your console.
Press the described button on the console and then the described button on your controller. The two should sync together perfectly fine.
Xbox 360 wireless controllers wont connect!
well you might want to press the little button by the battery pack at the top and the little one on the 360
1helpful
2answers
My second wireless controller for my xbox360 wont work.
You still have to hit the sync button on the controller and on the console to marry them. Just like when you first got the console. Just hit the small round button on the console that is between the memory card slot 2 and the power button, and the sync button on the top of your controller. The lights on both will spin then lock. They will be married and you will see the controller 2 light on on your ring.
7answers
The manuel that came with your xbox contains how to do that. I dont know off the top of my head.
Microsoft Xbox 360 Controller Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Joseph Murphy
Joseph Murphy
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
