Question about Texas Instruments TI-83 Plus Calculator
When I try to graph it says-ERR:INVALID DIM 1:QUIT
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Jun 03, 2014
5 Related Answers
Patrick
  • 56 Answers
SOURCE: My TI-82 wontdraw graphs!
one of your stat plots is on. either go to 2nd y= and turn off yout stat plots. Or reset your caculator. 2nd then + then 7 then 1 then 2
Posted on Feb 05, 2008
Anonymous
SOURCE: my graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
Posted on Jul 15, 2009
olenelson
  • 7 Answers
SOURCE: When graphing says ERR: INVALID DIM 1:Quit
You have two lists that don't agree in length.
Solution 1 (easy)
Press [y=] and look at the top line - one of your Plots is highlighted.
Move the arrow to the highlighted one, press enter to get it un-highlighted.
Solution 2 (permanent)
Press [STAT] - EDIT: [1] to edit your lists. Go to the bottom of the lists and see which one is the longest. Delete (DELETE, not clear) the "extra" entries in the longest list until all lists are the same length.
Posted on Oct 06, 2009
k24674
  • 8091 Answers
SOURCE: WHen trying to graph anything, ERR: INVALID DIM
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Posted on Oct 16, 2009
k24674
  • 8091 Answers
SOURCE: whenever I try to graph the y= I get an Err:
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Posted on Feb 21, 2010
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
My calculator will not graph the equations i put in under the y= button. it says "ERR:INVALID DIM 1:QUIT"
Oct 25, 2010 | Texas Instruments TI-84 Plus Calculator
When i press the graph button a screen that says: ERR: INVALID DIM 1:Quit
Oct 16, 2010 | Texas Instruments TI-84 Plus Calculator
I am trying to graph an equation and the following appears when I hit graph: ERR:INVALID DIM 1:Quit Do you know how to fix this? The same error comes up when I try Y=X
Feb 07, 2010 | Texas Instruments TI-83 Plus Calculator
When trying to graph anything, ERR: INVALID DIM appears..
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
Graph
Sep 09, 2009 | Texas Instruments TI-84 Plus Calculator
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
My graphing calculator won't graph anything
Jul 07, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
249 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
