Question about Regal Ware K6745S Kitchen Pro Bread Maker
Need Bread Pan Replacement
I love my Regal K6745S breadmaker. I have used it so much that the drive shaft broke away from the bread pan and I can not find out where to get replacement parts. Yes, I went to the Regal site, it is useless.
Posted by mmka1 on
  • Anonymous May 01, 2009
    The washer that fits on the driver for the dough paddle has come off. Is there any way to get a new pan or repair this with a new drive shaft?
Diane Pflug
  • 502 Answers
Ask here, they can get you every Regal manual + recipe book
Posted on Sep 07, 2010
The rubber (?) gasket between the kneading blade and the bottom of the bread pan has deteriorated and sluffed off into bread. Can I get a replacement?
Hi, That is actually a sealed bearing that the paddle shaft rotates on. It can not be replaced and you will need a new bread pan. Regal does not make bread machines anymore, but you may find one on eBay or Amazon. Hank
Dec 05, 2010 | Regal Ware Kitchen Appliances - Others
Where can I purchase a replacement bread pan for my Regal Kitchen Pro K6725 breadmaker?
web search- regal ware k6725 pro bread maker parts- click on 3rd site for parts
Oct 08, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
I have a Regal bread maker K6773. At the bottom of the drive shaft in the bread pan is a tan rubber gasket and below that was a black rubber gasket that has completely disintegrated and ended up mixed up...
Hi..That assembly is part of the sealed bearing in the bottom of the pan. That sealed bearing allows the shaft and paddle to turn freely. Unfortunately Regal stopped making bread machines and parts several years ago so the chances of you finding a replacement is rare. Hank
Sep 21, 2010 | Regal Ware Kitchen Appliances - Others
Drive shaft no longer turns kneading blade on model k6725
Either the paddle is frozen in the bread pan ( take pan & paddle out of machine and see if you can turn it by hand), or the belt has fallen off or has snapped. (Keep the bread pan out of the machine & run a knead cycle, look through the lid window and see if the motor shaft spins. Hank
Mar 05, 2010 | Regal Ware Kitchen Appliances - Others
Washer broke on shaft that runs the paddle. also shaft keeps workin out of bottom of pan
The sealed bearing that you are referring to is an assembly that is spot welded as a unit to the bottom of the bread pan. The items in this assembly can not be replaced. Yo need a new bread pan. Sorry Hank
Feb 17, 2010 | Toastmaster TBR15 Bread Maker
Ineed the Bread Pan for my Regal Kitchen Pro bread
Call the company listed in your manual. They will have the part you need.
Jan 11, 2010 | Regal Ware K6746S Kitchen Pro Bread Maker
Shaft won't turn.
The bearing that lets your paddle turn freely has frozen up. The bearing is lubricated and sealed at the factory, but as time goes by it freezes up.
One person suggested to soak it overnight in soapy water (warm) and try turning it by hand. If you are lucky this may work, or if not, a new bread pan is necessary.
Hank
Aug 31, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
I have the 5890 Sunbeam breadmaker, I love it except for the kneading blade bakes right in the bread, how can you give a loaf away with that in it?
You can take the paddle out of the bread pan after the last kneading cycle and before final rise. Do this rather quickly if you don't have a pause feature so you don't lose any rising time.
Take the bread pan out of the machine, put dough in a bowl, remove paddle, put dough back in pan, put pan back in machine.
Some people suggested to spray a small squirt of olive oil on the shaft to prevent sticking.
Hank
Aug 29, 2009 | Kitchen Appliances - Others
Need A Replacement Paddle
I have 2 breadmachines 1- K6745 & 1-welbilt ABM2H60 model. The paddel for the latter should work in the k6745. The female shaft of paddel is a little short but should do the trick, I think. Both machines have the normal type loaf pan, and the paddel did fit onto the shaft, so maybe looking at another machine w/ same style of pan will work also.
I really enjoy my K6745 but in a move I lost my manual could you e-mail a copy to me?
Aug 27, 2007 | Regal Ware K6745S Kitchen Pro Bread Maker
Kitchen Appliances - Others Logo
158 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Irene Tulloch
Marvin
Marvin
Tom Chichester
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
