This sounds really lame but I have never oiled this machine...it probably needs it but I don't know where the oil goes. The manual doesn't give instructions. i can't afford to mess it up. THANKS!
Usually, newer sewing machines will never require oiling. In fact, for most, if not all, it's BAD to oil them.
Is it making a weird sound when you sew? Or are you just being proactive and trying to take good care of your new baby?
It's not making a weird sound but the thread frequently gets all jammed
up . I have to constantly re-thread both top and bobbin thread. Then it
works for awhile then the cycle starts all over.
Couple of questions:
Are you using good thread?
By "good thread" I don't mean the spools that cost roughly what it costs to feed a family of four, but just good *quality* thread? Does it seem overly fuzzy to you? If it does (seem overly fuzzy to you), can you swap it out for another spool?
What's the tension?
To me, it really sounds as though the tension's messed up. That would result in the thread jamming and usually, breaking (sometimes even breaking the needle).
Another thing could be the *type* of fabric you're sewing.
If you're sewing fleece (or craft fur -- anything with a major nap), bit of material floats in to the bobbin case. When that happens, you have yourself an ooey-gooey, yucky mess.
If it's the material you're using, your only options would be to tough it out and keep taking a break to clean up your bobbin hook/race every so often or stop working on the project. :(
Lastly, it could be the needle.
Have you changed the needle? Needles tend to dull fairly quickly. And when they dull, they develop microscopic burrs that will snag the thread and fabric. That too, could be a possibility for what you're seeing.
When I took the bobbin
case out to check it out, remove lint, I could tell there was some oil.
Is this a newer machine? Sometimes you'll see that with newer machines. All that *should* be is extra blobs of manufacturer's oil. I get that, too, sometimes. As far as I know, it doesn't mean anything.
I just thought maybe it needed some oil.
It *shouldn't* if it were manufactured in the past 5 years or so. I think the sewing machine manufacturers were tired of us fooling with our machines and decided to protect us from ourselves!
*laughs because you shoulda seen me -- I was oil-crazy back in the day!*
Do you know how often I should change the needle?
Personally, I vary between ('cause I'm lazy sometimes) 24 hours and 36 hours of sewing. But I believe that the average expert will tell you to change it every 8 hours of sewing time.
Thanks so much for your time!
You're very welcome!
Holler back with more info when you have a chance! We'll figure this out, okay?! :)
Hi Sewcreative - you sound like you may be able to help with my problem. I have a Husqvarna 3310 (from 70's I think) that does not need oiling. Never had a problem til now. Stitching OK when slow but making a loud squealing sound as I sew. Can't be doing any good. Any suggestion of what I can check beyond cleaning the bobbin case area which seems ok? Thanks in anticipation.
It's not making a weird sound but the thread frequently gets all jammed up . I have to constantly re-thread both top and bobbin thread. Then it works for awhile then the cycle starts all over. When I took the bobbin case out to check it out, remove lint, I could tell there was some oil. I just thought maybe it needed some oil.
Do you know how often I should change the needle? Thanks so much for your time!
Well, after reading your comments, here's what I now think:
I'm sure I'm using good thread...so I'm safe. I think I should change needles and maybe check out the tension.
Thanks again...we'll see how this saga plays out today! I'm trying to make a quilt top.
