Cannot get dual cassette deck to record, denon DRW-660
I want to dub an audio cassette on my denon drw-660 but can't seem to get the record side to start up. I do not have the remote control.
Posted by videoexpress on
Anonymous
  • 121 Answers
Check the drive belts inside the unit could be broken or slipping. farr64
Posted on Apr 29, 2009
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Playback options
If I were you I would get that side repaired for the following reasons 1) the wear on the record head is the same on the B whether you record or play 2) the gap is a compromise if it is a record/play head and for play back only the quality is better albeit only seen on instruments . 3) Cassette machines will be very dear and scarce as the factories appeared to have stopped making them. If you have the quantity as I have then if your record side's head is more of value as you cannot record on the head 4) Is your recording side a "3 head " unit giving you "off the tape" recording capability.5) You loose the ability to do trick recording by adding voice with music
This is the reasons for the time being If it is the unit in your pic then it was a very expensive unit
May 25, 2013 | Denon Audio Players & Recorders
The cassette reader "A" on drw-660 dont work
It needs work. Take it to a Technician and it will work again. Dual cassette decks are built to low standards so you do not get the years out of them that you do with a solid single unit.
Mar 03, 2013 | Audio Players & Recorders
I need an operating manual for a Denon DRW660
You can download the manual at the following link.
http://diplo-best.com/review/DENON/DRW-660
Jun 03, 2011 | Audio Players & Recorders
Rubber bands
Drive belts are universal. Just measure the diameter of the old belts in MM and put that and the words "Cassette Drive Belt ...mm" into Google.
Jul 05, 2010 | Denon Audio Players & Recorders
Need instruction manual for denon drw-660 dual cassette deck
http://www.user-manuals.com/advanced_search_result.php?keywords=denon+drw-660+&osCsid=11873a748fd5790e73fdb0587299c24e&x=10&y=14
$10
You may find what you are looking for in another manual. Denon has some manuals on their website www.denon.com. Look for SUPPORT tab, then service manual. On the bottom of that page, they have info for some discontinued models. Read them and you may have the answer to your questions
Mar 15, 2010 | Audio Players & Recorders
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Apr 04, 2008 | Audio Players & Recorders
330 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
