LG LXD5230 System Logo
David Meghnagi Posted on Apr 29, 2009
LG DVD player Disc Error message even when playing lens cleaners!
My LG (LX-D5230) DVD player has stopped playing DVDs, saying "Disc Error" and ejecting every time I try anything, INCLUDING 2 different brand new lens cleaner discs that I've tried (philips and another). Any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2993
Points
Anonymous
Level 1:
New Friend:
  • Posted on Jun 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2993
Points
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
DVD player will not play Dvds error message saying incorrect disc
try running a dvd lens cleaner through it if that doesn't work then the dvd portion is not working but you can always use a regular dvd player plugged into one of the inputs.
You can purchase a DVD lens cleaner for under $10 just about anywhere DVD's are sold
My 2 1/2 year old LG dvd/vcr recorder will play some dvds but will not play others. It says unknown disc. I was told to try a lens cleaner; I bought one and the lens cleaner says unknown disc as well. ...
Your DVD /VCR says unknown disc because the
dvd which you have inserted is not of the supported format by player.
If you insert unsupported formats only it will say as unknown disc.This is not related with disc cleaners.
Please insert the supported formats and it will play the disc.
Thanx
Trouble playing DVDS
Try a good wet type cd dvd lens cleaner and you may need to upgrade the firmware check the LG website.
Good luck
Rich
4helpful
No DVD is playing and says disc error all times. The same DVD plays on my computer. I have tried many DVDs and the same error everytime
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it say disc error.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
2helpful
My dvd player will not play any dvds or cds... It says disc error
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say disc error.
By so doing your player would play all Cd's with no problem at all.
Good luck.
8helpful
2answers
My dvd player plays cds but wont play dvds says disc error or unknown disc
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Good luck.
2helpful
2answers
My LX d5230 has stopped playing Audio Cd's. It just spits them out showing "Disc Error". Any Ideas anyone?
Hi.
If you get Disk Error only on few CDs, then it can be the media (CD scratched, defective or dirty).
If you get the error on all or almost all CDs, then it is usually because of a lens problem.
You will need to clean the lens.
See the article below:
DVD player in my home theater system won't...
"Disc Error"
Try lens cleaner hope it will works.
1helpful
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
2answers
No Disk error message
I have the same problem. I opened the DVD player up and "blew out" dust. Still does not recognize that I have a disc in. HELP
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
