Sony DVP-NS305 DVD Player Logo
Posted on Apr 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony dvd/video combo dvd stuck inside
It's making noise like it wants to eject the dvd, but it won't. Any simple solutions other than taking the casing off?
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on Apr 29, 2009
Anonymous
Expert
Level 2:
Answers
121
Questions
0
Helped
36771
Points
285
Will it play the disc? try giving the door a little help when ejecting sounds like a slipping drive belt.farr64
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
37helpful
5answers
Magnavox DVD eject button fell in TV
Take a close look where the plastic button was--it if there would engage a tiny round black rubber like button---using a pencil eraser see if you can gently push the button.
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
1helpful
2answers
Dvd got stuck.it plays but wont come out..after several trial nothing work out..
remove lid on dvd and turn timing gears untill disc ejects.
1helpful
2answers
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Acer aspire 3500 DVD ROM making noise
type of noise ? It might just need a cleaning. Try using a compress air can to clean. Look inside to see nothing is stuck in there.
1helpful
Dvd tray wont eject
One way i have found is to (no joke) take the back panel off the TV BECAREFUL THERE IS HAZARDOUS VOLTAGE! Look to see if there is a DVD stuck in it, if so remove it. If this doesnt work let me know, i have other possible solutions
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
