Question about Juicers
Cutting blade for swiss made Rotel nutrimax juicer
2 Related Answers
Anonymous
  • 848 Answers
SOURCE: Jack Lalanne Power Juicer250
the power is not properly supplied to blade .....just check whether the connections are proper ....
Posted on Aug 09, 2008
Anonymous
SOURCE: Rotel Juicer
Once the handle has been pushed aside, it is easy to dismantle down to the perforated bowl. This is a push fir onto the black plastic boss and should wriggle off quite easily for cleaning.
Posted on Oct 29, 2008
When we juice, it turns and moves across the counter
Both the Omega and Acme juicers vibrate no matter what you do. I found a worn shredder
blade actually produces less vibration. However this involves filing the cutting burrs down
and resetting the blade to chute gap. If you're up to it, take the blade out and file each row
of burrs about halfway down. Then with the juicer fully assembled, unlock the set screw on
the center of the bottom, turn it clockwise until the chute contacts the blade, and back it off
a half turn. The set screw actually raises and lowers the motor spindle. Both companies
would not agree with this, but this solution comes from operating my 21 year old Acme.
I recently replaced the blade and the juicer immediately began tap dancing. Went back to
the old blade.
Jan 16, 2011 | Omega 1000 Juice Extractor
Aug 09, 2008 | Jack Lalanne Power Juicer 250 Watts
Who might sharpen the shredder blade???
This is a good one because a worn blade
actually causes less vibration. You can
sharpen the blade using a drill. Use a drill
bit about the same width as the cutting burrs
and drill into the face of each one ever so
slightly, almost perpendicularly. Assemble
the juicer and unlock the adjust screw on
the center of the bottom. Turn it clockwise
until the blade contacts the chute, then back
it off a half turn. Don't forget to tighten the
lock nut. I've been using the same blade
for years.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
Taking the Jack Lalane power juicer apart
Maybe its the orange tool you're talking about. The tool has two ends. It fits in the blade. The blade has 2 holes. Fit it in the 2 holes and turn it to screw the blade out. Careful not to cut your hands.
Jul 14, 2009 | Jack Lalanne Power Juicer 250 Watts
How to clean my jack lalanne power juicer
Take the top part of the juicer off so that just the shreder is visable. On top of the shreder are 2 small holes on either side of the blades. a handle devise with 2 pins came with the juicer. put the tool pins into the holes and twist counter clock wise. The blade will come off then rest is simple and the unit can be disassembled. If you have lost the tool disassembly will be more dificult but can still be accomplished using a cloth on top of the blades and twiting counter clock wise. Careful though or you will cut yourself
Jan 05, 2009 | Jack Lalanne Power Juicer 250 Watts
Rotel Juicer
Jun 03, 2008 | Juicers
Cutting Blade won't come off
I do not have a tool so I used two pen tops, turned the blade counterclockwise while ensuring the filter basket stayed put. It worked well
Apr 16, 2008 | Jack Lalanne Power Juicer 250 Watts
Where can we locate a parts store?
The cutting blade can be found at http://www.waringproducts.com/ret/.  Waring now makes the juicers.  Good luck!
Mar 11, 2008 | Juicers
Juicers Logo
135 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
