SOURCE: Treo 650 Hotsync Problem
For error 4014 On the PC go to palmone/user...../ and rename the "exchange" directory to .old When you hotsync again it will work without the error and will create an empty directory. Worked for me with my new LifeDrive and TomTom software. For error 4004 The only thing that worked for me.. Was to do a hard re-set and then to reload each non-Palm problem, one by one, checking each time to see that I didn't get that same 4004 error message. This was time-consuming, but it worked.
SOURCE: Converting from Palm Pilot TX to iTunes
There is probably a compatibility issue between the TX, Pocket Copy, and Iphone. TX is pretty picky about what can be used to transfter information. They only recommend Outlook and the one that is included on the TX CD.
TX and IPhones are different systems as well. You could try to get the files exported from the TX into a CSV and see if you can import the files into Iphone that way, if it will import them.
Good luck on that one.
SOURCE: Palm 755p Treo does no sync all contacts--missing contacts on Palm
Ive had this same promblem. I had to uninstall Palm desktop and Hotsync Manager and reinstall a different one that I got from the internet.
trweekes
SOURCE: Transfer contacts and calendar from Palm to iPhone and iCal
The best way is to transfer the Calendar and Contacts to Outlook. The iPhone can then be synced with Outlook.
Unfortunately, tasks and memos do not transfer. You will need to find other 3rd party apps that are supported on the iPhone and transfer your data to them.
Two examples are:
1. Evernote - This is good for memo. You can export your memos and then import them into Evernote. unfortunately, when I did this, it was a bit tricky. I even had to write a little PERL script to create the format that it wanted.
2. RemembertheMilk - this is a todo application
