Question about Daewoo Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
sayed
My Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Posted on Nov 03, 2014
3 Related Answers
Wisherwasher
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
masteria
Rohit Asthana
  • 355 Answers
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Posted on Jun 16, 2009
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: LE CODE WHAT MEANS. DAEWOO
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Posted on Apr 21, 2011
My Washing Machine Daewoo DWF 200P Displayed ( E9 ) in screen
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Daewoo Washing Machine Error Fault Codes
https://removeandreplace.com > 2015/11/02 > daewoo-...
Nov. 2, 2015 - The Daewoo generalized error fault codes below are to give you an "idea" as to what part is at fault. ... Daewoo Washing Machine Error Fault Code = E9 ... If your Daewoo Washing Machine Error Code is not listed here, check ... Mine is Daewoo washing machine DWF-8288, showing E1 and won't spin and ...
Daewoo DWF 806 MF does not hold water
if the drain hose gets too far down the drain ,it can get into the water that stays in the trap and cause it siphon out of the washer.try pulling it back up about three inches and zip tie it off to one of the fill hoses,
E9 error message on daewoo washing machines top loader DWF-240PSTE
DWF-200MS I have a DAEWOO DWF-200MS top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
7helpful
2answers
LE CODE WHAT MEANS. DAEWOO WASHING MACHINES MODEL: DWF-772W
10helpful
3answers
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
7helpful
3answers
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
4helpful
2answers
What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
Good Luck!
2helpful
Daewoo washing machine dwf-75ts
Washing Machines Logo
Top Daewoo Washing Machines Experts
Paul Bade
Fahr Quad
Paul Carew
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
