Panasonic Lumix DMCLX5 Digital Camera Logo
Jim Marshall Posted on Nov 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset factory setting - Panasonic Lumix DMCLX5 Digital Camera
  • Official Brand Answer 350 Answers
  • Posted on Nov 01, 2013
Panasonic
Level 0:
Answers
350
Questions
0
Helped
84499
Points
487
Go into the "Setup" menu and scroll until you reach "Reset" press the "Menu/Set" button and then follow the screen prompts.
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
It's possible to reset the DTXPRESS electronic drum kit to its factory default settings by performing a Factory Reset. Here's how you can do it:
Press and hold the [DRUM KIT] and [SAMPLE] buttons while turning on the power switch.
The display will show "FACTORY RESET OK?"
Press the [DRUM KIT] button to execute the factory reset.
The display will show "INITIALIZING" while the reset is being performed.
When the reset is complete, the display will show "COMPLETED".
Note: Performing a factory reset will delete all user kits, samples, and other custom settings that you have made. Be sure to save any custom kits or settings that you want to keep before performing the reset.
Factory resetting my Samsung Galaxy S7
hi Linda.
How to factory reset the Galaxy S7
  1. Swipe down from the top of the screen to pull down the Notification Shade.
  2. Tap the Settings button. It looks like a gear.
  3. Swipe up to scroll down on the settings screen.
  4. Tap Backup and reset.
  5. Tap Factory data reset. ...
  6. Tap RESET DEVICE.
  7. Tap ERASE EVERYTHING.
How to factory reset the Galaxy S7 ' Android Central
https://www.androidcentral.com/how-factory-reset-galaxy-s7
to read up more you could go to this link.
how to Factory resetting my Samsung Galaxy S7 Google Search
1helpful
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
1helpful
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Netflix com
Performing a factory reset erases all of your settings and account information and restores your
1 Press home to go to the Home screen. 2 Highlight settings , and then press select to display the Settings screen.
3 Highlight factory reset, and then press select .
4 To continue with the reset, select factory reset. To cancel the reset, select back.
  • 5 When prompted, highlight yes to confirm that you want to reset your player, and then press
    select
Mfc7340 where is factory reset
Restoring all settings to the factory settings, you can restore all the settings you have changed to the factory settings. These settings will stay until you change them again.1 Press Print Setting.2 Press a or b to display Factory Reset.3 Press Factory Reset. 4Press Yes to confirm.5 Press Stop/Exit.
4helpful
My vizio has input locked
Hello
Reset the device to its factory settings. To reset it to factory settings, enter "Setup", select 'Reset All Settings", press [=>] button to reset the TV to its factory settings. All parameters, except the parential lock will be reset to it original factory settings. If you for got the pass code, just enter its factory reset passcode [0000]; Eventhough the set will report this to be wrong passcode, input [0000] once again. This will unlock the passcode, and you have to set a new passcode. OK.
2helpful
3answers
I forgot the lock code to my rumor touch and can still access the phone but cannot lock it because i forgot the code... what do i do?
hi dear.. please help me.. i forgot my NOKIA E63 restore factory settings lock code. please send the how to reset my lock code to [email protected]
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
