Computers & Internet Logo
J
John Sproul Posted on Nov 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Assemble stand I accidentally attached the base pieces backwards. While they connected very easily, they will not separate.
Toby White-Beebe
Level 2:
Scholar:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 52 Answers
  • Posted on Nov 02, 2013
Toby White-Beebe
Expert
Level 2:
Scholar:
Night Owl:
Answers
52
Questions
Helped
8402
Points
118
There is a tab that locks the assembly onto the monitor. Find the tab, press it & unslide the assembly off of the monitor or arm. The rotate properly, reslide into position until you hear it snap the locking tab into position. You should never have to pry this tab to umlock it. -DellTech1
Is the base stand attached or is it a separate piece?
when We buy the tv its comes with it as Its separate piece. We have assemble it to the tv.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
2helpful
Assembly instructions for dw7350 mobile base
You are correct...the base is not pre-assembled as stated in the instructions. However it is a very easy task. The four base parts slot together in a fairly obvious way. The bolts to use are actually packaged separately and marked as "Bolts for Base". There are four bolts in total. One bolt goes in each corner of the base assembly. I put my bolts through from the bottom with the nuts and lockwashers on top. I did this to minimize the ground clearance although now that it is assembled it probably wasn't necessary. Once the four base pieces are together you can follow the instructions as printed. BTW, when bolting the four upright channels to the base, two of them use the same bolts as the ones holding one end of the "U"-shaped wheel supports. The instructions didn't mention this. It is also fairly obvious. In the end, no problems putting this extremely sturdy stand together. I'm glad I bought this to go along with my planer!
Toshiba TL515U base assembly
there are few educational videos at "u-tube" about your particular TV set.
Try to watch those. It might help you to assemble the base. Generally speaking, most TV stands are identical in design. Some requires assembly, using screwdriver, some snapping in together. But all of them are attached to the TV via screws. Manufacture won't take a chance to attach 51" TV to the stand, just by snapping it into. cnettv.cnet.com/...tl515u/9742-1_53-50108300.html
Good luck,
Alex.
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 • Toys
1helpful
I Have a 87 corvette that drops fuel pressure if left unstarted for more than a day or two.
Fuel Pressure Regulator REMOVAL & INSTALLATION 5.7L (VIN 8) Engine NOTE: The pressure regulator and base are factory adjusted and serviced as a complete assembly only. Do not try to remove the regulator cover. 1985-88 VEHICLES
  1. Disconnect the negative battery cable.
  2. Properly relieve the fuel system pressure.
  3. Remove the fuel rail from the vehicle, as outlined earlier in this section.
  4. Remove the front crossover tube retaining attaching screw and crossover tube retainer from the right hand rail side.
  5. Unfasten the retainer-to-base screw assembly and rear crossover tube retaining from the pressure regulator and base assembly.
  6. Separate the left hand fuel rail and plug assembly from the right hand fuel rail and plug assembly.
  7. Remove the bracket-to-rail attaching screw, 2 bracket-to-base screws and the regulator and base bracket.
  8. Unfasten the screw that attaches the fuel outlet tube to the right hand rail.
  9. Remove the base-to-right hand rail assembly. Fig. 1: Typical fuel pressure regulator assembly - 5.7L (VIN 8) engine 91035g26.gif
  10. Twist the regulator and base assembly to the remove it from the fuel outlet tube.
  11. Unplug the base-to-rail connector.
  12. Remove and discard the O-ring seals from the following components, noting the location and sizes of the O-rings to ensure proper placement during installation:
    • Connector
    • Fuel outlet tube
    • Rear crossover tube
    • Front crossover tube
  13. Check the O-rings and sealing surfaces for damage that may prevent proper sealing.
  14. Installation is the reverse of the removal procedure. Tighten the retaining screws to 44 inch lbs. (5 Nm).
  15. Connect the negative battery cable, then turn the ignition to the ON position and check for fuel leaks.
Misassembled black 18" Holmes stand fan with remote (HSF1809R)
Hello cdelune. Glad to see you fixed the problem but Im having the exact same issue with the fan! Not sure what to do with the pole with the frayed ends and how to connect it with the plastic falanges. Ive been at it a while now so do you think you could help me out and post exactly what you did to fix it? Thanks.
18helpful
2answers
How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
1helpful
Model KSM90 10 speed ultra power stand mixer leaking oil at the shaft where mixer tools attach. Is there a repair kit which includes a oil seal or something like that at a reasonable price?
Hi. Your mixer needs to be serviced, have old grease and oil removed, parts cleaned, then re assembled with new grease. Remove the tapered-pin from the planetary gear, remove planetary gear, clean lubricate and re install. Chevron FM ALC EP-2 is a "Food Grade" lubricant, meaning that it's safe for human consumption if it accidentally gets into food. There are no seals, only bushings. The existing bushings will hold back the new grease. The oil has separated from the base of the grease. If you don't use your mixer very often, start it up about once a week to keep the grease properly mixed.
If you'd like more info on your mixer goto kitchenaid.com, look up your model # download the PARTS drawings. Use these drawings to re-assemble and to determine if you need any replacement parts. Be prepared to wait at least a month for your parts to arrive.
If this Solution assisted you, please rate it. ricardok45
3helpful
3answers
Passenger Windshield Wiper Not Working
how do you get the wipper assmbley off
Base removal of mounted plasma
Pls do not take any other screws, other than silver screws.if you take the 6 pcs of silver screws and pull the stand it will come out easily.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
