Question about NorStar Lands Phones
Nortel/Norstar ICS phone system - Calls go to wrong voicemail on calls forwarded with NA
Posted by William Deckman on
Phonemaster4
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Check the forward no answer setting for number of rings on each extension that has ringing lines. The number of rings should be more than the auto attendant is set to answer with.
Posted on Jan 27, 2014
5 Related Answers
Anonymous
SOURCE: Remote Voicemail - How do you do it T7316
Call the phone system.
When you hear the voicemail greeting,
Press "* *" (thats 2 stars)
then just like sitting in front of the phone.
Posted on Nov 20, 2008
ynotphone
ynotphone
  • 192 Answers
SOURCE: call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Posted on Mar 19, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How do I retrieve recent incoming calls
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
Posted on Mar 27, 2009
Anonymous
SOURCE: call forwarding on t7316 nortel system
turn on feature 84.... turn off feature # 84
Posted on Jun 25, 2009
Anonymous
SOURCE: Norstar T7316 can't make call forward work
This worked for me:
Feature 4, 0 1 (xxx) xxx-xxxx
Mike
Posted on Oct 08, 2009
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
I have a 3-line Nortel T7316e phone. The feature to un-forward calls from one of my lines is not doing so. I need to un-forward calls from one of my lines.
Usually it should unforward calls by pressing the CALL FWD key again. Check out the user manual to be sure 100%. You can download the manual here: Nortel t7316
Sep 06, 2013 | Nortel Norstar 16-Line PBX Speakerphone
All calls go directly to voice mail
The phone is probably forwarded to voicemail. Leave the handset down and dial "Feature # 4". This will remove the call forwarding option. There are also automated call forwarding options -- Call Forward-No Answer, and Call Forward-Busy. CF/NA will transfer calls to voicemail after 4-rings (for instance). CF/B sends all calls to voicemail if you are on your phone. System programming, by a certified technician, is required to make changes to these options. Hope this helps.
Jul 15, 2010 | NorStar Meridian M7310 Phone
Voicemail ext shows "not available"
Sounds like its trying to use the default greeting using you name from the company directory. I would verify that the mailbox greeting is in place (f981>admin>greet>rec>prime>).
Jul 15, 2010 | NorStar M7324 Telephone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Nortel T7316E Voicemail
It sounds like both phones are set to ring on incoming calls and both phones are set to call forward to voice mail box with the same amount of rings . you should turn off the ringing for both phones that way it will not jump between the to mail boxes . now when a call is trans it will go to the box .
Mar 24, 2009 | NorStar T7316E Corded Phone
Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Oct 17, 2008 | NorStar Flash Voicemail Power Supply Only...
Norstar 7310 forwards to Voicemail
Sounds like the phone is set for Call Forward Busy/ No Answer instead of Call Forward No Answer. If you cahnge it call forwarding it should work correctly. ....Mike
Aug 08, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Lands Phones Logo
139 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
