Yes, you can force the TV to display HDMI by accessing the input selection menu. Here's how to do it:
- Press the "Input" or "Source" button on your Sharp remote control. This should bring up the input selection menu on the screen.
- Use the arrow buttons on the remote to select "HDMI" as the input source.
- Press "OK" or "Enter" to confirm the selection.
- The TV should now display the HDMI input signal from your device.
If this doesn't work, you may need to check the HDMI cable and make sure it's connected properly. If the cable is damaged or faulty, it can cause issues with the HDMI signal.
Regarding the eeprom problem, it's not recommended to modify the TV's firmware or eeprom unless you're a qualified technician. If you suspect that the TV's firmware is causing the issue, you should contact Sharp customer support or a professional repair service for assistance.
