Help! I took some precious pics and I cannot retrieve them because of this error.
I tried to use my card reader but it was not compatible with the SDHC card.
Do you think my pics were deleted somehow? What do you suggest I do?
I just bought a new camera - Panasonic Lumix DMC - TZ3 and separately bought a 4GB SDHC memory card. When I put the card into the camera it says Memory Card Error; Memory Card Parameter Error.
Is there anything I can do? Or is this a dodgy card? I haven't taken any photos yet.
have tried Exif Untrasher
WHAT IF THE SDHC CARD IS NEW/ AND IT SAYS Memory Card Error; Memory Card Parameter Error////
You may try some card recovery software, recommended asoftech photo recovery that helped me before.
http://www.asoftech.com/apr/
If needed, you may do a quick format of the card, and then use asoftech photo recovery to recover files.
Your sd card is sadly corrupted if you downloaded the pictures to your computer your in luck then get a new sd card and download all the pictures from the computer if its a labtop put the sd card on the bottom hope this helped vote thumbs up for more answers hope this helped
-Yashar G.
Don't worry! You can easily retrieve your lost/deleted files back. Few days before, my memory card also appeared "Memory Card Error" . To recover my data back I searched a lot. I found good data recovery software which helped me to recover my deleted files. It can restore your lost data only in few mouse clicks. It is 100% safe, and i m happy :) with its results as i got my photos back. Here I am providing you the link of that software, and I hope it will solve your problem.
Download link: http://www.any-data-recovery.com/product/photo-recovery.htm
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
Hi - You will need to get an SDHC reader and then try the following procedure.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
