I have tried to set up PS3 to new Sanyo 42" LCD using the HDMI cable, but i can only get sound, no picture. I tried both HDMI channels and 2 cables. My friend took the PS3 to his house and it works fine in his HDMI channel.
Thanks
Gillian
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
