Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
My RCA MM52110 is unable to complete the auto adjust feature, it suggests covering the set with a blanketto make room darker? Does that sound correct?
1 Related Answer
Anonymous
SOURCE: No Sound on RCA L46WD22
I own the L46WD22 for a few months and lost the sound and analog inputs, only HDMI worked, apparently this is a design flaw and they should have recalled all units. I didn't really needed the speakers because I have a sony receiver where I playback the sounds, but I decided to repair it myself after I neglected to take it out to the repair center and use the warranty. If you have a little soldering experience you can fix it, or you can buy the fuse and take it to any repair center, the problem is a surface mounted fuse that is located in the PCBA where all the signal inputs are, the component location is 1C33 the fuse has the letter F printed on it, you can't miss it, it's about 2 inches behind the tuner where you plug the coaxial cable. the fuse I bought it's marked with a G letter, it's 750mA, I just soldered it on top of the one it has, now I can hear the speaker and use the analog inputs (and now I'm the hero and have a very happy wife). the whole fix took me about two hours
Posted on Sep 28, 2008
1helpful
I chanded the brightness at about 8:30 several day a go. So for the last few nights, at that time the screen gets darker???? But all day long it is fine???
Hi Mary,
Sounds like you've got your TV settings making changes automatically for you based on room lighting. My suggestion would be go to settings, display and then look for anything that may be checked that says auto or programmed and see if that helps.
Screen out of adjustment
steamjet1,
Try to fix it by using the convergence adjustment. Use the manual method to set it if the auto feature fails. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure about $300.00 USD for your model.
-Chris
My rca Thompson MM52110 tv picture is too dark even in the light setting mode is there a way I can fix it so I can watch movies and play games in a lighter setting?
Is it a DLP set? Could be the bulb going bad, some times the arc tube in the bulb darkens with age, the arc still fires but less light comes out
How can i change the aspect ratio on RCA mm52110. the HD picture is stretched tall but very clear.
I'm going to take a stab at this out of the dark but okay!
1) is there an 'Aspect' or a 'picture size' button on your hand held remote control?
2) If you scroll through your 'On Screen Menu's' do you find a feature that will change the aspect or picture size?
Many of these TV's have this button feature on the remote control.
Blessings,
A/V Media Tech Guy
1helpful
Sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
2answers
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
RCA MM52110 FUSE keeps blowing
should be covered under your insurance might give them a call.
other wise i would check the bridge rectifier,
Colors keeps changing
you sgould contact you rca dealer for the warranty flsh to replace the convergence connector,the fault can be intermittant at times and create other syptoms also
RCA Projection TV MM52110 Won't Power Up
Being able to read a schematic and understanding how a TV works are two different things. These chassis that RCA used in these sets can be somewhat complex to troubleshoot. I would geuess that unless the power light comes on at all then you have a dead power supply in the TV.
Internal Cleaning Of MM52110
Really it all depends on how handy you are. Yes thes sets do have three lenses and a couple of mirrors that should be cleaned every year or two, and a few tweeks on the screens and focus controls. In my opinion, this should be done by someone who knows what they are doing. A TV set is not a place to be experimenting around inside of.
Open Questions:
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
