Question about Samsung N150 Notebook
Battery plugged, one second charging the next not charging
Posted by swerct on
Grand Canyon Tech
  • Samsung Master
  • 3,866 Answers
Battery is most likely your issue in most cases your best bet would be try taking out the battery and if the system shuts off while it's plugged in chances are it's the power brick..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 01, 2013
When I plug the unit into the AC charger I hear a
w+pnt0gwwvrvgaaaabjru5erkjggga=
I would check battery, it may not be good, If you need battery look online it will be less expensive than buying from mfg.
Oct 27, 2017 | Cobra Electronics Cobra Jumpstarter Air...
How do you know if the battery is charging.
To find out if your battery charger is working on your jet3 .
First thing you do is make sure its plugged in
Second locate your meter next to the plug on your chair
Third when plugging in the cord make sure your meter moves to the center of the meter.
If this works congrats your charger is working.
Jan 22, 2011 | Jet 3 Ultra Power Chair
VOSTRO 1710 BATTERY WON'T CHARGE
If the battery will not charge, try this:
1.) First, power reset the unit by powering it off, unplugging it from AC power, removing the battery, then push and hold the power button on the unit for about 60 seconds.
2.) Next, plug the AC adapter back in (LEAVE THE BATTERY OUT), power the unit on. Does the unit power on?
If yes, Power the unit off and put the battery back in, let it charge overnight. If, after this the battery will still not charge, you will have to replace the battery. Contact the OEM to ensure you get the correct battery.
If no, remove the AC adapter carefully, look inside the DC port (where the charger plugs in to the laptop) you should see a small silver pin. Is this pin missing or bent? If the pin seems to be in good shape, then most likely you will have to replace the AC adapter. If it IS bent or missing, then you will need to contact a laptop repair center.
Oct 08, 2009 | Dell Vostro 1500 Notebook
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Soney cybersthot dsc-s30 charging issue
I replaced the battery. The new one keeps a charge and lets the ac adapter charge the battery. I plan on purchasing a new battery and recycling the old one.
Feb 17, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
After fully charging my Motorola H700 all night, it loses its charge after an hour or two. When I plug it back in, the green light comes on in seconds. What's up with that?
seems some components inside your phone has shorted out. overnight charging is not recommended for it could cause overheating of the components of your phone which in time develops shorts.shorts , of course consumes rapidly the charge of the battery and it damages the battery also. have your phone diagnosed and fixed. next time if possible, remove the phone from the charger when it fully charged.
Nov 01, 2008 | Motorola Cell Phones
V3 dead but keypad flashing
I had exactly the same problem. After unsucessfully looking for a solution on the net I removed the simm chip and set it aside. The next day, I put it on PC usb charge and left it overnight. The next day, I powered it up and it worked. I turned it off and replaced the simm and it is now working fine. Go figure...
Jul 29, 2007 | Motorola Mobility RAZR V3
Samsung N150 Notebook Logo
163 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
