Question about HDTV Supply 12x8 stackable digital/analog audio matrix switch over cat5
Video matrix switch uninitialized? - HDTV Supply 12x8 stackable digital/analog audio matrix switch over cat5
Mike Anthony
    New Friend:
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Posted on Mar 18, 2014
Whats the remote control 3 digit code for matrix tv? Using newstar ntr-B81E
Remote codes for Matrix TVs
3 Digit Remote Codes for Matrix TVs:
020
021
025
028
4 Digit Remote Codes for Matrix TVs:
0000
0001
0031
May 23, 2018 | Matrix Televison & Video
Tip
Kramer VS4x4ycyl Manual Download
Download Kramer VS4x4ycyl Video Audio Matrix Switcher Manual
Have you misplaced your Kramer VS4x4ycyl Video Audio Matrix Switcher Owners Manual?
Would you like a digital, searchable, pdf version of the VS4x4ycyl Video Audio Matrix Switcher User Guide?
Follow this link (& click FREE) to download a pdf version of the VS4x4ycyl Video Audio Matrix Switcher installation instructions.
I hope that helps.
_______________________________________________
on May 09, 2010 | Audio Players & Recorders
LG-10165FU. How can I replace the bearing?
Well, there is a Utube video here: https://www.youtube.com/watch?v=XaFF2-Rl8Nc But frankly, for the uninitiated it's a nightmare. 90% of novices either give up part way through or get it wrong and damage the bearings or seats in the process. I would honestly get a professional to do it, or buy a reconditioned machine (Which will cost about the same as the repair!)
Sep 21, 2015 | Washing Machines
Switch to hdmi
http://lsm-video.en.alibaba.com/
3DHDMI Splitter, 4k HDTV SPLITTER
3DHDMI Switcher, 4k HDTV SPLITTER
3DHDMI Converter,Audio
Splitter,Audio Converter,Audio
Matrix and others AV Products.
You are welcome to contact us today.
Duke Chu
Jan 02, 2014 | Televison & Video
3d ghosting
is the splitter rated for 3d??
Nov 17, 2013 | Startech VS440HDMI 4x4 HDMI Matrix Video...
Can I cascade multiple HDMI Matrix Switchers?
HDMI is a high bandwidth digital signal and you cannot cascade multiple HDMI Matrix units. It will degrade the video quality and you might run into EDID and HDCP issues. For further queries visit KVMSwitchTech or Call at 866-865-7737 (TOLL FREE).
Jul 10, 2013 | Computers & Internet
How can I to control multiple HDTVs in several different rooms via a HDMI matrix switch?
There are HDBaseT HDMI Matrix solutions for applications like yours. I would recommend to visit KVMSwitchTech as they offer a wide range of 4x4 HDMI Matrix and 8x8 HDMI Matrix solutions with HDBaseT support and zone remotes.
http://www.kvmswitchtech.com/8x8-cat5e67-hdmi-matrix-switch-with-hdbaset-over-single-cat5e67-cable-includes-8-hdbaset-receivers-p50030.htm
Apr 04, 2013 | Aten 4x4 HDMI Matrix Switch witch
VIDEO TO HDMI?
Solved - I learned Sony 720 and 820 receivers do not up convert video component (Wii) in to hdmi out. Need to upgrade to 920. Thanks anyway.
Dec 27, 2008 | Matrix Video Storm CRM84D HDMI,...
Fuji A200 xD card uninitialized
OK There are 3 problems that  a company like Fuji should have avoided:
1. Directing one to "re-initialize" the chip and not providing any directions for doing so.
2. Calling it "initializing" in the menu and "formatting" in the camera menu.
3. Building a camera that blitzes the chip when the USB cord is accidentaly disconnected without following the ritual.
The FIX: Turn the camera on. > Switch from the red camera icon to the green arrow icon on the ring around the shutter button. > Press the "menu/OK" button. > Under the "Erase" menu, scroll up to "Format." Press "Menu/OK" button. > Re-format (aka "re-initialize') the chip and lose all images stored on it. Whoppeee!
Nov 25, 2008 | Fuji FinePix A400 Digital Camera
Audio selector does not mute unselected inputs
There is a matrix switching IC on the circuit board that switches and routes the sources. This IC (for the audio) may be damaged, or it is not being properly commanded by the uPC controler. You will have to send the reciever to a qualified service tech to have this verified. Troubleshooting this can get involved if the fault is more than just the matrix IC.
Jerry G.
Apr 13, 2007 | Sony STR-DB790 Receiver
HDTV Supply 12x8 stackable digital/analog audio matrix switch over cat5 Logo
Top HDTV Supply Televison & Video Experts
Lawrence Oravetz
Are you a HDTV Supply Televison and Video Expert? Answer questions, earn points and help others
