SOURCE: Samsung DVD-R135 / R136 - Will not load blank discs
Hello, First be sure your using the correct disc DVD+ or DVD- RW etc.
I would recomend using high quality discs as players/recorders are very picky about cheap media. Try using Imation name brand discs. They read well in most anything. If it has worked fine & then started having this problem I would first check to see if your using the same discs that have always worked with it & if so then you may want to open the unit & clean the laser lens with a cotton swab lightly soaked in rubbing alcohol. Especially if it has been smoked around or is in a dusty environment.
SOURCE: Samsung DVD-VR375 says "load" but tray for DVD/VCR won't open
I think you have problem in DVD deck assembly the owner manual won't help you if still under warranty bring back to Samsung if out of warranty you can buy the DVD deck from Samsung and replace by yourself
Let me know if you need part number for the DVD deck
SOURCE: DVD Player won't open
Try this. This works on some brands and models.
Power up the unit. Using the remote, press and hold the 'STOP' button for about 5 seconds. Release and press the 'OK' button.
SOURCE: how to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
SOURCE: disc is stuck in the tray - samsung dvd R130
Without knowing more of your specific situation, it sounds like the disc is physically stuck and is blocking the motor mechanisms from ejecting. There should be 1-2 screws on each side & one at the rear of the player to remove the outer casing. When you open it, any obstructions should be obvious. The screws should be easy to figure out with an arrow pointing to them stamped into the medal, kindof looks like: =>
