Question about Samsung HLN617W 61" Rear Projection HDTV
Black and white picture only
Have a samsung 50" projection tv-works normal except piture in black and white only- all lights on front off- bulb replaced 1 year ago-heard color wheels shatter- if color wheel broken will it only have black and white? or do you have a solution?
Posted by spudzhome on
  • Kajj96 Apr 29, 2009
    My HLN617 display just turns B&W. When power on, all 3 lights look normal. After 15 seconds, there is a humming noise. Is this the color wheel damaged, or the digital control board? Thanks.
    KT
  • Anonymous Mar 16, 2014
    We moved TV from one room to another now do not get a color picture.
Anonymous
    Scholar:
  • 33 Answers
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Posted on Apr 29, 2009
  • fa93 Mar 13, 2011
    My HLN617W had catastrophic color wheel failure with most of the wheel gone. It was not making a loud noise but was only BW including menu's. Color wheel replacement fixed the problem.
Originally got blinking lights to indicate a bad bulb. Had a spare bulb that I installed. Now a very loud noise from color wheel and only a black and white picture.
Bad color wheel is cause of noise and black and white picture in tv, please replace color wheel to solve the issue.
Required color wheel is available in SamsungParts for $120
Thanks.
May 13, 2011 | Samsung HLM507W 50" Rear Projection HDTV
Samsung DLP HLN467W
This tv have a colors wheel.Now ur tv colors wheel it dead.The colors wheel is dead,no colors black&white,loud squiling noises,loud motor noises.All indication of the colors wheel is dead,spinning off of is axis,not function anymore.Hire a tv tech.for this.Not machanically incline,don't atemp to change the colors wheel ur selp.
Jul 12, 2010 | Samsung HLN467W 46" Rear Projection HDTV
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung dlp model hlp5067wx
the color wheel has to be replaced. (Technican Job) this device is inside the light engine,
Jan 06, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Philips 50" rear projection- Washed out picture.
You need to change the CRT Fluid. This is a common problem on the  older projection TV sets.
You can get the fluid and instructions on how to change it from www.TvRepairKits.com.
Dec 19, 2008 | Philips 9P5034C 50" Rear Projection...
Only black and white
The same thing happened to my HLP5063W. Researching the internet forums I concluded the problem was with the color wheel, which I replaced. As it turns out the old one was completely smashed. Go to www.jangro.com for replacement instructions.
Jul 05, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
616 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
