Question about Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC
Ok so I have catz 5 since roughly 2011. However I got bored with it and stopped playing. I moved all the .PET files I had into a folder and uninstalled the program. I went back to play it about a week ago, installed it and moved my previous pets into the game. I found out my one pet (which was a hexed bunny pet.) is pregnant and most likely became pregnant before I uninstalled it back in 2011. It seems to be a stuck pregnancy since it's been about 5 days since I noticed her pregnancy. I've tried the method of moving the clock forward but seeing as I installed the game on a flash drive instead of on my actual computer it doesn't seem as though the clock is affecting it. Is it possible she could become unstuck on her own? I am willing to wait if that is the case. If not What can I do to try and unstick her pregnancy?
    New Friend:
  • 3 Answers
APN SETTINGS
Posted on Nov 01, 2013
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: Catz 5 problem with installation.
if you are trying to install the game from a CD or DVD the cause could probably be that the CD or DVD is damaged, try cleaning the media. if u are trying to install the game from a cd or dvd try coppying all the files on to your had disk and then open the setup procees from the hard disk.
Posted on Jun 12, 2007
Anonymous
SOURCE: Dogz/Catz 5 compilation Vista Help
Firstly, open a folder. You need to click on 'Organize' >> 'Folder and Search Options'. On here click on the 'view' tab, then check the box for 'Show hidden files and folders'. Click OK on this.
Next go onto C: and click on your user name, then click on AppData.
In here, click on 'Local' >> 'VirtualStore' >> 'Program Files' >> 'Ubi Soft' >> 'Studio Mythos' >> 'Petz 5' >> 'Adopted Petz'.
Here is the file path if you need it:
C:\Users\Your User Name\AppData\Local\VirtualStore\Program Files\Ubi Soft\Studio Mythos\Petz 5\Adopted Petz
Hope this helps!
Jenn xo
Posted on Jan 12, 2009
Anonymous
SOURCE: Cannot install or play Petz 5!!!
Delete or rename Program FIles\Common Files\Installshield I did that and it works.
Posted on Dec 26, 2009
Anonymous
  • 78 Answers
SOURCE: dogz 5 not installing!!
then the problem is not with ur computer but with ur cd. use isobuster and create an image of the cd. then mount it. now u can run and install it. there is an easier way get a new copy of the software
Posted on Feb 12, 2010
RainDreamer
SOURCE: For petz 5, i just
Your resolution is too high. Reduce it to 1024x768 and they will appear normal.
Posted on Jan 14, 2011
I need to reinstall the software but don't won't to lose all my pets (one just had 4 babies). Is there a way around this? IS there a file I can save somewhere else, then add it back in when I reinstall?
I can't tell you from experience because I have never played that particular game. However any other game i've ever played where you save your progress, there is always a profile or saved game file.
You will want to open My Computer-->C:/ (hard drive)-->Program files--> Ubisoft-->Petz in there you will find a file or folder with an obvious name (user name, profile name, saved game) something along those lines. Save the entire folder if there is one or just the single file to your desktop, reinstall the game....when you reinstall just make sure you put the file or folder back exactly where you found it.
Note:: You may need to start a new profile when you reinstall, afterward just put your saved file back where it belongs for it to work properly. (Sometimes the game needs to create the profile folder or saved game folder in the directory.)
***** Last thing is when you do uninstall the game it may ask you if you want to delete user settings and saved game files. If it does click no, that way you won't have to worry about loosing your stuff at all.
Hope this helps, post back if you need any further assistance. Thank you for choosing Fixya!
Jul 17, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
Petz 5 not working. error message comes up
When you unintall Petz 5 you need to not save the petz, which is an option just before it starts uninstalling. Unistall, Then install it again, and run the game from My Computor, Petz, then play.
hope it works for you.
May 28, 2009 | Ubi Soft Catz 5 (Windows) (680901) for PC
Petz 5 problem/ .cat files
.cat files are secure catalog files. Are the files in the correct folder? The file location should be something like Programfiles>Ubi Soft>Studio Mythos>Petz 5>Resource>Catz. If the files aren't in the Catz folder under resource, they won't work.
Mar 11, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
How to delete cats on Catz 5
Go to Start > Settings > Control Panel open up Add/remove programs.. locate & uninstall
Jan 07, 2009 | Ubi Soft Catz 5 (Windows) (680901) for PC
Tabby Cat Missing from Adoptoin Center!
Download (or make) a breed with a name that would be after Tabby in the alphabet. That should fix it.
Jan 02, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
Hope this helps!
Jenn xo
Sep 15, 2008 | Ubi Soft Petz: Dogz 5 and Catz 5...
Missing Toys and South Seas Island Problem
you need to delete the registery for it, i had the same problem, every item i tryed puting in my carying case would disapear and not show up tell i restarted the game, these are the steps:
go to start click Run
type REGEDIT in the run box and hit OK
now you need to find the Catz 5 or Dogz 5 folder and delete it, dont worry your game will still play, you will still have your pets, just all the toys will be reset
hope this helped
Jun 03, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
Petz 5 minigames!!
It's an obsticle course. Get your pet(s) to jump through the hoop, (quietly) sit on the stool, walk the balance, & go through the poles.Y.W!
Apr 25, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
Dogz 5 Won't Work!
This happened to mine 2. I uninstalled it, but the folder was still there, so I went on search, local disk, and searched ubi soft then deleted it. After that it worked, except I've noticed if you press save pets when uninstalling, it doesn't work.
If I want to keep my pets, I go into the ubi soft folder, adopted petz, then I drag my pets to a new folder I make on the desktop. When the game is reinstalled, I put the pets in the folder back into the adopted petz folder.
This has been the solution for me, but I don't know if it will work for others. Good luck!
Nov 25, 2007 | Ubi Soft Catz 5 (Windows) (680901) for PC
Jun 12, 2007 | Ubi Soft Catz 5 (Windows) (680901) for PC
Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC Logo
137 people viewed this question
Top Ubi Soft Computers & Internet Experts
Pavel Pranovich
Pavel Pranovich
Ricky Sharma
Ricky Sharma
k24674
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
